Help in FPGA/VHDL - need to create an activation signal
jpaulobenevides
Newbie level 2
Help in FPGA/VHDL
I need to create an activation signal for a process and i connected it to a key in a FPGA DE2 of Altera. The
problem is that right after i program FPGA, the process runs before i even turn the key on. Can anyone help me?
Re: Help in FPGA/VHDL
CHeck whether the key is active High or Active low.. and how you have initiated the signal.I think maybe you have initiated the signal in the reverse manner.
Also , if you supplied the signal (enable to the process ) in the sensitivity , check for the initial conditions and also the required conditions to enable the process.
