Amit Dalmia
Newbie level 6
In your post #8 attached pictures you show that screens. This screens are painted ?
Yeah, the screens are painted
I think you're saying that you want an indication that the transmitter is ok.
You could achieve that by connecting a battery directly to the transmitter. The transmitter has three pins - GND, +ve and INPUT.
Connect a 555 circuit to the INPUT pin. See **broken link removed**for a circuit. You want to use the 'astable' circuit on that page. This circuit generates pulses.
Now the circuit is continuously sending RF pulses, so you know that the transmitter is ok.
You could get a resistor (lets call it R3) and place it in parallel with R1 in that astable circuit.
Your detection wire would form part of this new resistor connection.
It will change the frequency of the pulses. If the wire breaks, then effectively R3 becomes
disconnected, and the frequency changes.
So, you have an indication that the transmitter is ok (if the transmitter fails, you will
get no pulses), and you have an indication that the wire is ok (if the wire fails, you will
get a different rate of pulses).
The thing you need to concern yourself with is power consumption; are the screens intended to last for hours or days or weeks?
If you're transmitting pulses rapidly, then the battery will not last long.
You may wish to transmit (say) a short train of pulses every 60 seconds, or every 5 minutes.
That is a more sophisticated circuit. At least the simple 555 and transmitter circuit is a 'proof-of-concept'.
The more sophisticated circuit would need to be designed to consume less power when it is not
transmitting, and transmit less frequently.
You'd use a zigbee module on each screen, and one for monitoring all of the screens.
I think by brainstorming you could find different ways to achieve what you want, but unfortunately you may need to do that based on your knowledge of these screens. For example, if they are inserted in a specific holder, then there could be contacts on the holder to allow you to put all the embedded wires in (say) series, so that you get a single indication if any of the screens are faulty, and then rely on just a single transmitter.
In general, if you have a problem of identifying via radio one of multiple nodes, then Zigbee is possibly one of the more low-cost methods of doing it. Lower cost would be to use the simple tx modules from ebay that I mentioned, but the communication is one-way, and you could only identify them if they transmitted at different times, with (say) a different pulse rate, or an encoded value. That may be possible if they are designed to transmit at a random period.
Since you don't need such a frequent update, them the simple module method would work, if you wish to have a transmitter in each screen. In that case, use a simple microcontroller (e.g. a small AVR/PIC) to transmit a code at a pseudo-random time (e.g. approximately daily) using the tx module, so that it is unlikely to clash with any of the other screens.
If the receiver doesn't get a response from any of the screens for a couple of days, then you know that the screen is faulty.
In single quantities, a small AVR is a couple of dollars, plus a few for the tx module.
If you want to get started with AVR microcontrollers, use a guide such as**broken link removed**. (Or use a PIC, it really doesn't matter).
Your transmitter INPUT pin would be connected to one of the microcontroller pins, and the code you write would pulse the INPUT pin so that the transmitter
turns on.
At the receiver end, you'd use a receiver module, and connect the OUTPUT of the receiver to a microcontroller.
