Help-HFSS simulation with Master/Slave Boundary
liux2355
Newbie level 3
Newbie level 3
I really need help with the Master/Slave Boundary in HFSS.
I want to simulate SRR array using Master/Slave Boundary. I don't know how to set up the phase delay. I just want to simulate TEM wave normal to the structure and see S21 parameter. Should I set phi and theta to zero?
Anyone help me how to do this?
Thank you.
Hello
can any one send me Hfss manual on how to apply master-slave boundary conditions other than ensoft tutorial???
If the wave is at normal incidence, there is no phase difference between your boundaries. That only happens when the wave is at some oblique angle of incidence. In this regard, normal incidence is extremely easy with HFSS.
Hope this helps!
