help for mifg mos inverter hspice netlist
aminmahdi
Member level 1
Member level 1
pmos inverter
hi
i need the hspice netlist of 2-input fgmos "inverter" in mosis 0.35um.
vbiase change from 0 to 1 with 0.12 steps.
please write netlist for view output gragh that is here.
thanks.
inverter spice netlist
The netlist depends on your model for these devices.
If you paste the model fot them, I can provide you the netlist.
netlist inverter circuit
hi
the model is here. if possible please write hspice netlist for above inverter circuit.
mosis 0.35um parameters is here:
* DATE: Nov 11/04
* LOT: T47H WAF: 1003
* Temperature_parameters=Default
.MODEL CMOSN NMOS ( LEVEL = 49
+VERSION = 3.1 TNOM = 27 TOX = 8.1E-9
+XJ = 1.5E-7 NCH = 1.7E17 VTH0 = 0.5365213
+K1 = 0.6337104 K2 = 0.0177398 K3 = -3
+K3B = 1.4725837 W0 = 1E-8 NLX = 1.229512E-7
+DVT0W = 0 DVT1W = 0 DVT2W = 0
+DVT0 = 0.8663647 DVT1 = 0.4261199 DVT2 = -0.1844574
+U0 = 465.6348277 UA = 1E-13 UB = 2.183307E-18
+UC = 6.385989E-11 VSAT = 1.292247E5 A0 = 1.5265836
+AGS = 0.1976301 B0 = -1.061701E-7 B1 = -1E-7
+KETA = -6.125392E-3 A1 = 3.426511E-7 A2 = 1
+RDSW = 930.9944484 PRWG = -1.5177E-14 PRWB = -0.0378837
+WR = 1 WINT = 6.936585E-8 LINT = 9.318575E-8
+DWG = 6.919826E-10 DWB = 3.153613E-9 VOFF = -0.15
+NFACTOR = 2.5 CIT = 0 CDSC = 2.4E-4
+CDSCD = 0 CDSCB = 0 ETA0 = 0.0680086
+ETAB = -0.016658 DSUB = 0.6175276 PCLM = 0.8465914
+PDIBLC1 = 5.36705E-4 PDIBLC2 = 5.750557E-3 PDIBLCB = 0.1350732
+DROUT = 0.0288486 PSCBE1 = 3.104229E8 PSCBE2 = 9.984618E-7
+PVAG = 1.0986866 DELTA = 0.01 RSH = 3.7
+MOBMOD = 1 PRT = 0 UTE = -1.5
+KT1 = -0.11 KT1L = 0 KT2 = 0.022
+UA1 = 4.31E-9 UB1 = -7.61E-18 UC1 = -5.6E-11
+AT = 3.3E4 WL = 0 WLN = 1
+WW = 0 WWN = 1 WWL = 0
+LL = 0 LLN = 1 LW = 0
+LWN = 1 LWL = 0 CAPMOD = 2
+XPART = 0.5 CGDO = 3.6E-10 CGSO = 3.6E-10
+CGBO = 1E-10 CJ = 1.000624E-3 PB = 0.8
+MJ = 0.3455404 CJSW = 1.115924E-10 PBSW = 0.99
+MJSW = 0.1003172 CJSWG = 1.64E-10 PBSWG = 0.99
+MJSWG = 0.1003172 CF = 0 PVTH0 = -1.640302E-4
+PRDSW = -23.2644781 PK2 = -3.187322E-3 WKETA = 3.651506E-3
+LKETA = -6.683635E-3 )
.MODEL CMOSP PMOS ( LEVEL = 49
+XJ = 1.5E-7 NCH = 1.7E17 VTH0 = -0.4494732
+K1 = 0.9268825 K2 = -0.0147312 K3 = 0.4018043
+K3B = 3.4987502 W0 = 1E-8 NLX = 4.940566E-9
+DVT0 = 0.7475473 DVT1 = 0.6347494 DVT2 = -0.3
+U0 = 117.7450362 UA = 1.126102E-9 UB = 2.489171E-21
+UC = -1E-10 VSAT = 1.179005E5 A0 = 0.8887774
+AGS = 0.1195937 B0 = 1.157583E-6 B1 = 5E-6
+KETA = 3.77163E-3 A1 = 1.126695E-3 A2 = 0.3
+RDSW = 3E3 PRWG = -0.0914343 PRWB = -0.20117
+WR = 1 WINT = 6.155779E-8 LINT = 5.726981E-8
+DWG = -6.921666E-9 DWB = 2.892018E-9 VOFF = -0.0361606
+NFACTOR = 0.8753188 CIT = 0 CDSC = 2.4E-4
+CDSCD = 0 CDSCB = 0 ETA0 = 0.2802295
+ETAB = -0.0971535 DSUB = 1 PCLM = 1.4478649
+PDIBLC1 = 3.124819E-3 PDIBLC2 = 1.928447E-3 PDIBLCB = -0.1
+DROUT = 0.0987209 PSCBE1 = 3.904658E10 PSCBE2 = 3.849713E-9
+PVAG = 0 DELTA = 0.01 RSH = 3
+XPART = 0.5 CGDO = 3.58E-10 CGSO = 3.58E-10
+CGBO = 1E-10 CJ = 8.423313E-4 PB = 0.7404059
+MJ = 0.3433523 CJSW = 8E-13 PBSW = 0.75
+MJSW = 0.91 CJSWG = 6.4E-11 PBSWG = 0.75
+MJSWG = 0.91 CF = 0 PVTH0 = 5.98016E-3
+PRDSW = 14.8598424 PK2 = 3.73981E-3 WKETA = -5.675314E-3
+LKETA = -0.0199083 )
