Help for a module in project
Shyam Joe
Junior Member level 3
I need a verilog code for switch with 50 inputs,12 outputs and 12 select lines. Both the inputs and outputs are 256 bit wide. in select lines i need to mention the which 12 inputs should appear at the output. For ex. if I need the inputs 2,5,9,14,20,25,27,32,36,40,44,49 to appear in the output i should give these numbers in select lines. Kindly note that all of these inputs are 256 bit wide. please help me to write the code
