[help!] Error while compiling in modelsim
jianhuachews
Member level 2
Member level 2
Hi guys.. I was writing a testbench but errors occurred when i compiled it. could anyone tell me wht's wrong? I know it might look pretty obvious but i just don't see it.
The errors while compiling the test bench goes
Signal "altb_i" is type std_logic; expecting type std_logic_vector.
Signal "agtb_i" is type std_logic; expecting type std_logic_vector.
Signal "a" is type std_logic_vector; expecting type std_logic.
Signal "b" is type std_logic_vector; expecting type std_logic.
TB code
Library IEEE;
Use IEEE.std_logic_1164.all;
Entity lab4bTB is
end;
Architecture comparator of lab4bTB is
	signal altb_i, agtb_i: std_logic:='0';
	signal aeqb_i: std_logic:='1';
	signal a,b: std_logic_vector(3 downto 0):="0000";
	signal agtb_o,agtb_out, aeqb_o,aeqb_out, altb_o, altb_out :  std_logic;
begin
UUT : entity work.lab4b port map(altb_i, agtb_i, aeqb_i, a, b, altb_out, agtb_out, aeqb_out);
tb : process
	begin
		wait for 50 ns;
		aeqb_i <= '1'; a<="1110";
		wait for 50 ns;
		aeqb_i <= '1'; b<="1111";
		wait for 50 ns;
		aeqb_i<='0'; agtb_i <='1';
		wait for 50 ns;
		a<="1010"; b<="1111";
		wait for 50 ns;
		agtb_i <='0'; altb_i<='1';
		wait for 50 ns;
		a<="1111"; b<="1010";
	end process tb;
	aeqb_o<=aeqb_out;
	agtb_o<=agtb_out;
	altb_o<=altb_out;
end;
program code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity lab4b is port (
		a,b: in std_logic_vector(3 downto 0):="0000";
		altb_i: in std_logic:='0';
		aeqb_i: in std_logic:='1';
		agtb_i: in std_logic:='0';
		aeqb_o, agtb_o, altb_o: out std_logic
end;
architecture comparator of lab4b is
begin
	process (agtb_i, aeqb_i, altb_i, a, b)
	 begin
		if (aeqb_i='1') then
		 if (a=b) then
			aeqb_o <= '1';
			agtb_o <= '0';
			altb_o <= '0';
		 elsif (a>b) then
		 	agtb_o <='1';
			aeqb_o <='0';
			altb_o <='0';
		 elsif (a<b) then
		 	agtb_o <='0';
			aeqb_o <='0';
			altb_o <='1';
		elsif (agtb_i='1' or (altb_i='1' and a > b)) then
			agtb_o <='1';
			aeqb_o <='0';
			altb_o <='0';
		elsif (altb_i='1' or (agtb_i='1' and a < b)) then
			agtb_o <='0';
			aeqb_o <='0';
			altb_o <='1';
		else
			aeqb_o<='0';
			agtb_o<='0';
			altb_o<='0';
		 end if;
		end if;
	end process;
end;
Thanks in adv!
The signals inside the entity instantiation was not in the correct order. Replace it with the below line:
UUT : entity work.lab4b port map(a,b,altb_i, aeqb_i, agtb_i,aeqb_out, agtb_out,altb_out);
Hi vipinlal, thanks for helping out! I didn't know that the order actually affect the compilation.. It's actually working right now. Can you tell me more about it?
hi
in your testbench line
it should be order with
end;
Thanks guys! I've gotten the waveforms i wanted but i was told that my vhdl code design is wrong and that it should be in hierarchy design. I don't get it. What's with hierarchy design coding and mine? And how should i go about implementing hierarchy design in my program?
I have been reading for hours and i still don't get it..........
