Sure you are using suitable transistor parameters?yes i am using spectre circuit simulator... no it is not working in simulator
yes i am using spectre circuit simulator... no it is not working in simulator.......
and how can mosfet turns on if vdd is less than threshold.....? in this circuit vdd is 80mv.... so i don't think mosfet will turn on
you could be right... but i can't increase my power supply as i am trying to simulate it under ultra low power condition .... (Thermal energy harvesting) ..... my vdd must be in between 80mv to 200mv....
as i am trying to simulate it under ultra low power condition .... my vdd supply could very form 80mv to 200mv..... so what do you think, what kind of step-up voltage source should i use.... can you explain details of step-up voltage source... e.g
1). what should be the time period for this step-up voltage source?
2). rising time? falling time? time period?
3). what should be the peak value of this source?
