Help: the difference between via and contact in l
standup
Member level 1
I'm puzzled by the differences between via and contact in the manufacture process? thanks for your reply in advance
Re: Help: the difference between via and contact
Contact name is used when it connects the lowest level metal(usually metal1) with poly.
Via term is used when it is used for connecting two metal layers.i.e(via 1 for connecting b/w metal 1 and metal 2,via2 for metal 2 and metal 3 and so on..)
Adding to Chikva's point, a contact is used to connect POLY or P+/N+ DIFFUSION to the lowest level metal.
Vias are interconnects between successive metal layers.
