helix antenna prob. : hfss
abhi_kolkata
Member level 5
hi,
im faced with the problem of simulating a helix antenna in hfss. i have created a valid helical antenna with ground plane and coaxial feed .but the actual simulation is taking a lot of time, and getting struck just after initial meshing.
so does anybody have any idea of how to reduce the simulation time and get it simulated sucessfully.may be i need to use any suface meshing approximation for the solid helical surface (i am in doubt).OR some other effective method.
witing fo ur replies
with regards
abhi
danteh
Newbie level 2
if you use 16 segments per turn and square section of wire, you obtain a very important reduction of time and memory use.
For example: I have used it in a helix antenna (bifilar helix, 2 turn)
tools helix: 2:30 hrs and 130000thetraedros
segment aprox : 0:02 hrs and 7000 thetraedros, with the same radiation pattern and the same impedance.
abhi_kolkata
Member level 5
hi,
but i don't know how to assign, say, 16 segments per helical turn in hfss.
could u kindly tell me how to do that.
with regards
abhi
danteh
Newbie level 2
there two ways of doing it:
1) to create 16 square cross sections (without rotation) per turn and later to join the surfaces with 'unite' tool. select 'rectangle1' , 'rectangle2' apply 'unite', select 'rectangle2_1' , 'rectangle3' apply 'unite', etc.
The result is linear segments with square section with a helix shape. The position of the n-cross section is:
xn: r cos (Φn) r: radius helix Φn: 0, pi/8 , pi /4 , ......
yn: r sin (Φn)
zn: n*pitch/16 pitch: height per turn
2) to create 1 square cross sections and create a Line with segments (xn,yn,zn) and later use tool 'swep along path' to generate all the helix at once.
regards, Dante from (Instituto Argentino de Radioastronomia)
Twinkal
Newbie level 3
i m phasing the problem to design helical antenna for 12GHz.may be due to some problem of calculating pitch. so pls will u tell me how to calculate?
