woutput
Newbie level 3
constant value required
I hope you can help me on this problem, I've been working on it for some days now.
When I simulate the following VHDL code, I receive no errors and the results are good.
Part of my code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;--to use to_integer()
generic
AXI_ADDR_DATA_BITS : integer := 32;
VPAGE_BITS : integer := 12;
VPAGE_SETTING_BITS : integer := 3;
VPAGE_SETTING_OFFSET : integer := 10
port
PAGE_SIZE_SETTING : in std_logic_vector(VPAGE_SETTING_BITS - 1 downto 0);
VIR_ADDRESS_PAGE : out std_logic_vector(VPAGE_BITS - 1 downto 0);
VIR_ARAW_ADDR : in std_logic_vector(AXI_ADDR_DATA_BITS - 1 downto 0);
VIR_ADDRESS_PAGE <=
VIR_ARAW_ADDR
VPAGE_BITS
to_integer
unsigned
PAGE_SIZE_SETTING
downto
to_integer
unsigned
PAGE_SIZE_SETTING
But when I synthesise it, I get the following error: HDL-27 Constant value required
When I look up the error description (2nd hit: google for "constant value required" vhdl), it is not clear to me why this is not possible. I could image a combinatorial circuit (with a lot of multiplexers) which could solve this problem.
When I replace "to_integer(unsigned(PAGE_SIZE_SETTING))" with "3" it synthesises too. Like this:
VIR_ADDRESS_PAGE <=
VIR_ARAW_ADDR
VPAGE_BITS
downto
To solve this problem, I tried the following code:
FIX : for I in (to_integer(unsigned(PAGE_SIZE_SETTING)) + VPAGE_SETTING_OFFSET) to (VPAGE_BITS + to_integer(unsigned(PAGE_SIZE_SETTING)) + VPAGE_SETTING_OFFSET - 1) loop
VIR_ADDRESS_PAGE(I - (to_integer(unsigned(PAGE_SIZE_SETTING)) + VPAGE_SETTING_OFFSET)) <= VIR_ARAW_ADDR(I);
end loop FIX;
but I get the same error again. When applying the replace, it "works" again. Like this:
FIX : for I in (3 + VPAGE_SETTING_OFFSET) to (VPAGE_BITS + 3 + VPAGE_SETTING_OFFSET - 1) loop
VIR_ADDRESS_PAGE(I - (3 + VPAGE_SETTING_OFFSET)) <= VIR_ARAW_ADDR(I);
end loop FIX;
Can you give me a hint to solve my problem please?
I guess that my problem is "just" indexing a std_logic_vector with a signal as index.
Thank you in advance,
Wouter
Simulation: ModelSim SE 6.3a
Synthesis: Synopsys Design Analyzer
Part of my code:
library ieee;
generic
port
VIR_ADDRESS_PAGE <=
VIR_ARAW_ADDR
VPAGE_BITS
to_integer
unsigned
PAGE_SIZE_SETTING
downto
to_integer
unsigned
PAGE_SIZE_SETTING
VIR_ADDRESS_PAGE <=
VIR_ARAW_ADDR
VPAGE_BITS
downto
end loop FIX;
end loop FIX;
Wouter
