Rajat Girhotra
Newbie level 2
have Multiplier code but i am getting error stating - near "end" : expecting identier
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEE.NUMERIC_BIT.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity Array_Multiplier is Port (A,B : in bit_vector(3 downto 0); P: out bit_vector(7 downto 0); Result_Low : out bit_vector (3 downto 0); Result_High : out bit_vector (3 downto 0); end Array_Multiplier; architecture behavioral of Array_multiplier is signal C1, C2, C3: bit_vector (3 downto 0); signal S1, S2, S3: bit_vector (3 downto 0); signal XY0, XY1, XY2: bit_vector (3 downto 0); Component FullAdder_1_bit is Port ( A : in STD_LOGIC; B : in STD_LOGIC; Cin : in STD_LOGIC; Sum : out STD_LOGIC; Cout : out STD_LOGIC); end Component; Component HalfAdder_1_bit is Port ( A : in STD_LOGIC; B : in STD_LOGIC; Sum : out STD_LOGIC; Cout : out STD_LOGIC); end Component; Component AND_1_bit is Port ( A : in STD_LOGIC; B : in STD_LOGIC; C : out STD_LOGIC); end Component; begin AB0(0) <= A(0) and B(0); AB1(0) <= A(0) and B(1); AB0(1) <= A(1) and B(0); AB1(1) <= A(1) and B(1); AB0(2) <= A(2) and B(0); AB1(2) <= A(2) and B(1); AB0(3) <= A(3) and B(0); AB1(3) <= A(3) and B(1); AB2(0) <= A(0) and B(2); AB3(0) <= A(0) and B(3); AB2(1) <= A(1) and B(2); AB3(1) <= A(1) and B(3); AB2(2) <= A(2) and B(3); AB3(2) <= A(2) and B(3); AB3(3) <= A(3) and B(3); AB3(3) <= A(3) and B(3); FulLAdder_4_bit_0: FullAdder_4_bit port map (AB0(2), AB1(1), C1(0), C1(1), S1(1)); FullAdder_4_bit_1: FullAdder_4_bit port map (AB0(3), AB1(2), C1(1), C1(2), S1(2)); FullAdder_4_bit_2: FullAdder_4_bit port map (S1(2), AB2(1), C2(0), C2(1), S2(1)); FullAdder_4_bit_3: FullAdder_4_bit port map (S1(3), AB2(2), C2(1), C2(2), S2(2)); FullAdder_4_bit_4: FullAdder_4_bit port map (C1(3), AB2(3), C2(2), C2(3), S2(3)); FullAdder_4_bit_5: FullAdder_4_bit port map (S2(2), AB3(1), C3(0), C3(1), S3(1)); FullAdder_4_bit_6: FullAdder_4_bit port map (S2(3), AB3(2), C3(1), C3(2), S3(2)); FullAdder_4_bit_7: FullAdder_4_bit port map (C2(3), AB3(3), C3(2), C3(3), S3(3)); HallAdder_1_bit_0: HalfAdder_1_bit port map (AB0(1), AB1(0), C2(0), S1(0)); HallAdder_1_bit_1: HalfAdder_1_bit port map (AB1(3), C1(2), C1(3), S1(3)); HallAdder_1_bit_2: HalfAdder_1_bit port map (S1(1), XY2(0), C2(0), S2(0)); HallAdder_1_bit_3: HalfAdder_1_bit port map (S2(1), AB3(0), C3(0), S3(0)); P(0) <= AB0(0); P(1) <= S1(0); P(2) <= S2(0); P(3) <= S3(0); P(4) <= S3(1); P(5) <= S3(2); P(6) <= S3(3); P(7) <= C3(3); Result_Low(0) <= AB0(0); Result_Low(1) <= S1(0); Result_Low(2) <= S2(0); Result_Low(3) <= S3(0); Result_High(0) <= S3(1); Result_High(1) <= S3(2); Result_High(2) <= S3(3); Result_High(3) <= C3(3); END behavioral;
