Hantek oscilloscope vs Rigol oscilloscope, whats the better buy?
johnjoejohn
Junior Member level 2
Im debating on which one to buy, the Hantek MSO5074FG or the Rigol DS1074Z or Rigol DS1074Z-S. Same screen size for all models.
Im on a budget but im willing to spend ONLY if its worth it.
MSO5074FG spec: 4 channels, 70MHz bandwidth, 8 channel logic analyzer, 2 channel 25MHz function generator, 1M memory depth, $646
Rigol DS1074Z-S: 4 channels, 70MHz bandwidth, 2 channel 25MHz function generator, 12M memory depth, $818
Rigol DS1074Z : 4 channels, 70MHz bandwidth, 12M memory depth, $585
Buy what you need. Do you need a logic analyzer? Do you need a function generator? Can you find those functions cheaper (and at a later date) in stand alone products? Do you need 4 channels? 2 channel scopes are generally cheaper. It's up to you to decide the cost vs. functionality you need for your budget.
