guide lines for designing std cell layout
s3034585
Full Member level 4
hi can anyone tell me where can i find std cell layout design guidelines..
i am new to full custom layout design. thus i want some material on it..
thanks in advance..
I did never see any guidelines.
What I always used were few basic rules:
a) vertical size of all cells must be the same, would be nice if horizontal size are integer multiples of the min x (usualy min inverter)
b) VDD/VEE bus must be shared just by abuttment of the cells (the only metal going to the very edge of the cell)
c) use Met1 and Poly for routing not to block routing space above. If needed Met2 but as little as possible. (this sure depends for what speed you are designing)
d) all layer has to have at least min spacing from the edge of the cell not to violate DRC when butting them together.
e) each cell has to have its own well and substrate ties
f) I personaly do not like special I/O vias and "landing" structures because those usualy are not useful during final layout - in my opinion they cause more harm then anything else.
g) create filler cells 1x,2x,3x,4x.5x of min horizontal min size.
As you seen those are common sense practices but those surprisigly work....
    s3034585
thanks a lot for these tips...
as i am fresher to this area can u tell
what would be the best way to learn
thanks
hi
the best way to learn is to do some small design projects.u can find lot of material on standard cell design methodology on th internet and in this forum
