Hi-Q
Junior Member level 2
Hey,
if there is a high impedance circuit node, it's a good practice to surround the connected PCB pads and traces with guard ring structures and driving them with an as close as possible voltage with a low source impedance in order to prevent charges or leakage currents from reaching the high impedance node.
I wonder if it would be wise to not cover the guard ring traces with solder mask, so any surface currents (dust and moisture on the board) would really get caught by the guard ring instead of being able to cross it above the solder mask layer.
Thoughts?
Regards,
Hi-Q
Thoughts?
Regards,
Hi-Q
