rhjang
Junior Member level 3
When testing ORFS due to switching under -20 degree C.
PCS switching at frequency offset +/-400KHz will drop immediately from -30 to -20 when VBAT over 4.3V(only at CH750~CH810).
And PVT has an indentation at ramp up curve.
I tried two ways
1. Add an 2.2uF or 4.7uF cap (bypass to Ground) at VBAT trace-->
switching is improved under -20 degree C VBAT 4.3V, but still drop to -20 when VBAT is 4.4V
2.
After removing 10nF(bypass to Ground) at VBAT trace the issue solved.
But I dno't know how to explain it, does anyone have any idea?
I tried two ways
2.
