Register Log in
GSM module with SPI interface
ryan_13
Junior Member level 2
Hi there!
Does anyone here knows if the SIM340 GSM Module supports SPI interface? Meaning, I can control the module using the SPI instead of using the UART.
I want to control multiple GSM modules with only one UART and I plan to do this by configuring the UART as SPI and making the modules as slaves.
Thanks!
Siniša
Full Member level 6
Windsor ON Canada
I think UART only, but there are many types out there.
    V
ryan_13
thank you very much for the reply.. honestly, in case modules with spi really exist, i'm not quite sure how i'll make it work.. but then, I can't think of a way to control multiple gsm modules using just one uart..:sad:
pzw001
Newbie level 2
You can try to use a buffer with an OE input. Basically give every module its own buffer which you can enable individually. But your biggest problem (no matter how you are going to multiplex them) is how to handle the situations that multiple modules are sending something at the same time... Therefore the only decent solution is (IMHO) to use external UARTS which you control from your controller...
ryan_13
Thanks for the reply =)
Actually, my mcu has several uart pins and I can actually go with the task by using the other uart pins. If there's no any other solution, perhaps, I'll really have to settle with that.. =(
Thanks again..=)
Toggle Sidebar
