GPS interfacing with microcontroller
kulachi
Newbie level 5
i am making a project of gps data logger
can it b done with 8051 µC or i have to use AVR controller
also i have to interface PC-AT keyboard with it so this controller should also support that
help me on this plzz
thanks
A lot of GPS devices have the serial interface that you can connect to your controller.
Take a look at:
For good start.
And for the Keyboard, there are 100s of applications available for free on the internet:
If you had done a simple search on EDABOARD you would have found this:
Hope it helps,
Cheers,
/Farhad
con anyone help me on how to interface a microcontroller with a GPS reciever
@bramin19
usually the GPS has an serial interface,you should connect the serial port pins of microcontroller with GPS module.
Which GPS module you are using?
do a search in this forum .. you will get your answer.. I have answered it in many posts from many years...
DONT RE-OPEN OLD THREADS IF THAT DOES NOT SOLVE YOUR PROBLEM
actually i am trying to implement a project which generates an audio signal based on which direction i have to go and in which direction i am. so i am trying to use GPS reciever to calculate the present location . i have no thought of which GPS reciever to use.
can u suggest which one to use?
as i am familiar with 8051 i would want to interface GPS with 8051.
@bramin19
I have use GPS-610F from rfsolutions **broken link removed**
It supports NMEA format
you can also search for other gps modules which are common
Best Regards
