whizkid123
Junior Member level 2
- Joined
- Oct 6, 2011
- Messages
- 23
- Helped
- 1
- Reputation
- 2
- Reaction score
- 3
- Trophy points
- 1,283
- Location
- Singapore
- Activity points
- 1,421
Hi all,
I need to generate chip select signal for memory through address decoding. It will be combo logic only and the read/write access has to be performed in single cycle.
As Chip Select is transparent to Memory Address, whenever memory address is changing the csn is toggling in between the clock period also.
I want to remove that extra toggling on memory address lines when memory is not selected.
Any suggestions please ?
Thanks
Murali
Thanks
Murali
