Gilbert cell and its application in analog IC design
mohazaga
Full Member level 2
Have you any idea about Gilbert cell and it's application in analog IC design?
gilbert cell multiplier
Please specify your questions. there are lots of application of Gilbert cell in Analog IC design, especially in RF part.
current mode gilbert cell
even many applicaitons in RF?
I only see its application for mixer.
Any other applications?
thanks
gilbert cell ic
Is there any specific appl. ? how it's is used in RF?
If there any brief about it's feature?
tahnks
gilbert cell circuit
You can refer to
The design of cmos radio-frequency intergrated circuits.
Chap 12
gilbert cell vga
gilbert cell can be used in AGC(automatic gain control)
refer design of cmos analog integrated circuit by "behzad razavi"
page : 126
gilbert cell frequency range design
The gilbert cell is primarily used as a low distortion multiplier. IF you can find the original 'multi-tanh' principle article by Barrie Gilbert. A chapter is devoted to this in
Analogue IC Design: The Current-Mode Approach by Toumazou
gilebert cell
I read that it can be used to generate PTAT² current, but how, I don't understand it !!!
the multi-tanh principle gilbert
razavi has given a very nice explanation of the gilbert cell in section 4.5.
ads design gilbert cell
Many usage. e.g Mixer, Multiplier, Frequency Doubler, VGA stage, differetial function, Gm stage...
gilbert cell multiplier application
i want to know is gilbert cell can act as a Frequency Doubler...from this circuit,
the sentence"doubling the unity gain cutoff frequency of the amplifier"
means the frequency has become bigger since the bandwidth is bigger?
izzit the result will act like a mixer?
i am confuse about this gilbert cell..razavi's book(section 4.5)say it is voltage multiplier( the gain is double right?) and i read from " monolithic phase locked loops and clock recovery circuits" from behzad razavi says that this gilbert cell can act like a XOR gate.....
so, can this gilbert cell circuit used as a frequency multiplier of input of >24Mhz
cmos gilber cell multiplier
could someone can upload the book "monolithic phase locked loops and clock recovery circuits" from behzad raza?
thanks a lot!
Added after 5 minutes:
did you mean that the Gilbert cell could generate PTAT² current??
could you upload that paper?
thanks a lot!
Added after 8 minutes:
In fact, the Gilbert cell is just like a XOR gate. their waveform is just the same.
In my opinion, the waveforms of the Gilbert cell and the XOR are similiar to the comparator.
