Murugesh_89
Full Member level 5
- Joined
- Nov 23, 2012
- Messages
- 266
- Helped
- 7
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 1,298
- Location
- India
- Activity points
- 3,267
I am using a 3.3V operating pic microcontroller and the port output pins of uc is connected with 74HC245 ( 3.3v to 5v buffer ). The output of 74HC245 is connected as inputs to the attached circuit.
The attached circuit has 8 outputs and each is connecting with a 24V DC contactor. The contactor then connects with some ac motor. Totally six 3 phase induction motor and two single phase motor are controlled by this circuit.
The issue here is,
1. Some times, When i enable any one output say J1 the corresponding LD1 glows brightly but other led's are glowing blur. Hence all other outputs are also activated partially.
2. Some other time, When i enable any one output say J1 for long time the corresponding LD1(Brightly) and other led's(blur) switching On and Off periodically(like continuous pulses). Hence the other motors are also on/off periodically. But i dont change the output of microcontroller pin.
3. On power on itself with all the uc pins are low, the output led's in the circuit glowing blur and then it switched off.
Can anybody please help me on how to overcome this issue.....
Thanks...
The issue here is,
Thanks...
