I wanted to know if there are any ways of generating a 10 sec digital pulse (0.1 Hz; 5 sec ON and 5 sec. OFF). I need it as an enable signal for a project I am making (the ckt. will be enabled for 5 secs. to sample the inputs and then disabled for 5 secs. during its processing). Similarly, how to generate a 1 sec. pulse (1 Hz; 0.5 sec. ON and 0.5 secs. OFF). Any pointers will be thankfully acknowledged.
How about building a digital timer? Can be made in programmable logic, but also using a microcontroller or by assembling discrete logic ICs. All three variants will use a crystal oscillator if precise timing is intended.
Once you have 1 Hz, apply that to a 4017 decade counter. It divides by 10. To have 50 percent duty cycle, combine 5 diodes from 5 consecutive outputs.
To get 1Hz, is a 555 timer IC good enough? Or else if you need accuracy then start with a crystal oscillator, say 32kHz. Divide down cycles via one or more 4020/ 4040/ 4060 IC.
