analog_ambi
Member level 1
What is the best way to generate bias voltage VB1, VB2 and VB3?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hi analog_ambiWhat is the best way to generate bias voltage VB1, VB2 and VB3?
Hi againThis circuit will be power amplifier for ultra low power RF transmitter with EIRP=-5dBm and freq=2.4GHz.
May i ask you why ?The first stage shall be class AB
You can design a class E or C or perhaps F amplifier , in linear mode ( linear in your desired range of frequency ) it is up to the designer . or using a compact amplifier like Gali series .last stage is class A
