Geeks! Can you please Help!
haxaan
Newbie level 2
I need help in completing my semester project on verilog. I have made the code and it is compiling well but when I try to simulate, I get dozens of errors. I will greatly appreciate if someone can guide me with this coz I need to transfer the code on Spartan-3 fpga very soon. Here is the complete code I have mustered by now:
//MAIN stimulus file
module main();
reg CLK;
	reg	signed [31:0] WORD;
	wire	[7:0] PARABOLA;
	wire [7:0]	PHASE;
	wire SIGN;
	wire [6:0] TEMP;
	accumulator_phase pa(.word(WORD), .clk(CLK), .phase(PHASE), .sign(SIGN));
	parabola_gen pg(.phase(PHASE), .parabola(TEMP));
	format_converter fc(.signed_parabola(TEMP), .sign_ac(SIGN), .out_bits(PARABOLA));
	initial // Clock generator
		begin
			CLK = 1'b0;
			WORD = 32'b0;
			WORD[13] = 32'sh01000000;
		end
	always
		begin
			#20 CLK = 1'b1;
			#20 CLK = 1'b0;
			#20 CLK = 1'b1;
			#20 CLK = 1'b0;
		end
	initial
		$monitor($stime, CLK, WORD, PARABOLA);
endmodule
//PHASE ACCUMULATOR
module accumulator_phase(word, clk, phase, sign);
    input [31:0] word;
    input clk;
    output [7:0] phase;
    output sign;
	wire signed [31:0] word;
	wire clk;
	wire c1, c2, c3, c4, c5, c6, c7, c8;
	reg signed [31:0] x;
	reg signed [31:0] res;
	reg [7 : 0] phase;
	reg sign;
	initial
		begin
			phase <= 8'b0;
			x <= 32'b0;
			res <= 32'b0;
			sign <= 1'b0;
		end
   always @(posedge clk)
      begin
			phase <= res[30 : 23];
			sign <= res[31];
		end
	four_bit_adder fba1(res[3:0], c1, word[3:0], x[3:0], );
	four_bit_adder fba2(res[7:4], c2, word[7:4], x[7:4], c1);
	four_bit_adder fba3(res[11:8], c3, word[11:8], x[11:8], c2);
	four_bit_adder fba4(res[15:12], c4, word[15:12], x[15:12], c3);
	four_bit_adder fba5(res[19:16], c5, word[19:16], x[19:16], c4);
	four_bit_adder fba6(res[23:20], c6, word[23:20], x[23:20], c5);
	four_bit_adder fba7(res[27:24], c7, word[27:24], x[27:24], c6);
	four_bit_adder fba8(res[31:28], c8, word[31:28], x[31:28], c7);
endmodule
//FOUR BIT ADDER
module four_bit_adder(sum, carry_out, a, b, carry_in);
    output [3:0] sum;
    output carry_out;
    input [3:0] a;
    input [3:0] b;
    input carry_in;
  wire w1, w2, w3, w4, w5, w6, w7, w8, w9, w10, w11, w12;
  wire c1, c2, c3;
  xor (w1, a[0], b[0]),
    (sum[0], w1, carry_in);
  and (w2, a[0], b[0]),
    (w3, w1, carry_in);
  or (c1, w2, w3);
  xor (w4, a[1], b[1]),
    (sum[1], w4, c1);
  and (w5, a[1], b[1]),
    (w6, w4, c1);
  or (c2, w5, w6);
  xor (w7, a[2], b[2]),
    (sum[2], w7, c2);
  and (w8, a[2], b[2]),
    (w9, w7, c2);
  or (c3, w8, w9);
  xor (w10, a[3], b[3]),
    (sum[3], w10, c3);
  and (w11, a[3], b[3]),
    (w12, w10, c3);
  or (carry_out, w11, w12);
endmodule
//PARABOLA GENERATOR
module parabola_gen(phase, parabola);
    input [7:0] phase;
    output [6:0] parabola;
	wire [7:0] phase;
	reg [6:0] parabola;
	reg [15:0] result;
	reg signed [7:0] temp;
	two_comp tc(phase, temp);
	multiply mul(result,,phase,temp,1'b1);
	initial
		begin
			parabola <= 7'b0;
			result <= 16'b0;
		end
	always
			begin
				parabola = result[15 : 9];
			end
endmodule
//TWO's COMLEMENT
module two_comp(bits_in, bits_out);
   input [7:0] bits_in;
   output [7:0] bits_out;
	wire [7:0] bits_in;
	reg [7:0] bits_out;
	reg [7:0] bits_inv;
	reg [6:0] carry_tmp;
  initial
    bits_out = 8'b0;
	always
		bits_inv[7:0] = bits_in[7:0];
	fulladd addbit1 (bits_inv[0], 1, 0, bits_out[0], carry_tmp[0]);
	fulladd addbit2 (bits_inv[1], 0, carry_tmp[0], bits_out[1], carry_tmp[1]);
	fulladd addbit3 (bits_inv[2], 0, carry_tmp[1], bits_out[2], carry_tmp[2]);
	fulladd addbit4 (bits_inv[3], 0, carry_tmp[2], bits_out[3], carry_tmp[3]);
	fulladd addbit5 (bits_inv[4], 0, carry_tmp[3], bits_out[4], carry_tmp[4]);
	fulladd addbit6 (bits_inv[5], 0, carry_tmp[4], bits_out[5], carry_tmp[5]);
	fulladd addbit7 (bits_inv[6], 0, carry_tmp[5], bits_out[6], carry_tmp[6]);
	fulladd addbit8 (bits_inv[7], 0, carry_tmp[6], bits_out[7], carry_out);
endmodule
//FULL ADDER TO BE USED IN TWO's COMPLEMENT
module fulladd(a, b, carry_in, sum, carry_out);
    input a;
    input b;
    input carry_in;
    output sum;
    output carry_out;
	 reg sum;
	 reg carry_out;
	always @ (a or b or carry_in)
		begin
			case ({a,b,carry_in})
				3'b000:
					{sum,carry_out} = 3'b000;
				3'b010:
					{sum,carry_out} = 3'b010;
				3'b100:
				3'b110:
					{sum,carry_out} = 3'b100;
				3'b001:
				3'b011:
				3'b101:
				3'b111:
					{sum,carry_out} = 3'b001;
			endcase
end
endmodule
//MULTIPLIER
module multiply		(product,
			ready,
			multiplicand,
			multiplier,
			start);
   input [7:0]  multiplicand;
   input [7:0]  multiplier;
   input         start;
   output        product;
   output        ready;
   reg [31:0]    product;
   reg [4:0]     bit;
   wire          ready = !bit;
   reg           lostbit;
   initial bit = 0;
   always
     if( ready && start ) begin
        bit     = 16;
        product = { 16'd0, multiplier };
        lostbit = 0;
     end else if( bit ) begin:A
        case ( {product[0],lostbit} )
          2'b01: product[31:16] = product[31:16] + multiplicand;
          2'b10: product[31:16] = product[31:16] - multiplicand;
        endcase
        lostbit = product[0];
        product = { product[31], product[31:1] };
        bit     = bit - 1;
   end
endmodule
//FORMAT CONVERTER - FROM SIGNED TO UNSIGNED
module format_converter(signed_parabola, sign_ac, out_bits);
    input [6:0] signed_parabola;
    input sign_ac;
    output [7:0] out_bits;
   wire	sign_ac;
	wire	[6:0] signed_parabola;
	reg [7:0] temp;
	reg	[7:0]	out_bits;
	initial
		begin
			temp <= 8'b0;
			out_bits <= 8'b0;
		end
	always
		begin
			temp[7] <= sign_ac;
			temp[6:0] <= signed_parabola;
			out_bits <= $unsigned(temp);
		end
endmodule
Added after 3 hours 24 minutes:
Block diagram of my project
What are the errors?
At a quick glance, here are a few comments ...
1) Separate your design from your testbench. Your top design module (main?) should have the submodules instantiated and connected (accumulator, parabola ... ) and should also have your clock as an input. Your testbench should have your top design module instantiated, always statement for your clock which gets connected to your design module, and your monitor.
The testbench if for simulation. When you program your fpga, you only need your design modules (not testbench).
2) Your clock generation can be simplified to this ...
always
begin
#20 CLK = 1'b1;
#20 CLK = 1'b0;
end
3) This looks incorrect in main()
WORD = 32'b0;
you are trying to set 32 bits to WORD[13] which is only one bit of your bus. This also conflict with setting the bus WORD to 32'b0 as your are now initializing bit 13 twice.
4) Do not use "initial begin" in your design modules (only your testbench) as these are not synthesizable.
*edit*
5) your two's complement module is not inverting the input to the adders
should be :
bits_inv[7:0] = ~bits_in[7:0];
