Aug 3, 2011 #1 A AutoDriver Newbie level 4 Joined Jun 20, 2011 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,322 When you use Verilog for full chip gate-level simulation, do you use delay on standard cell library? Why? Do you use delay on the test program? When do and when do not? Why?
Aug 3, 2011 #2 A atulaxc Member level 1 Joined Jan 25, 2010 Messages 39 Helped 5 Reputation 10 Reaction score 5 Trophy points 1,288 Activity points 1,467 Delays are required on IP/RTL models involved in gate-level sims. These Verilog #delays insert required routing delays on actual (hardware) paths.
Aug 5, 2011 #3 L ljxpjpjljx Advanced Member level 3 Joined May 5, 2008 Messages 968 Helped 80 Reputation 162 Reaction score 56 Trophy points 1,308 Location Shang Hai Activity points 4,679 you should specify a file to load all delay!
