Fully Differential Op Amp integrator (Cadence)
mretsh91
Junior Member level 3
Hello ,, I am designing an integrator using fully differential amplifier in cadence ....i tried modeling the opamp using vco's ....and it worked as an inverting amplifier ...but when replacing the resistor with a cap ...the cct is not working
I need help please
Why not showing us the circuit? I suppose, without a circuit you will not get a usable answer .
