Full Bridge synchronous rectifier controller malfunctions in LTspice
T
treez
The attached is a LTspice simulation of a full bridge with synchronous rectifiers using LTC3723 and LTC3901 . (LTC3901 is a sync rect controller)
If the 2:1 signal transformer has Lp = 10mH, then the sync rect drive malfunctions. If I increase LP of the signal transformer to 11mH (keeping the 2:1 turns ratio), then it functions properly.
(The signal transformer feeds the SYNC pin of the LTC3901)
Why is it malfunctioning?
The Sync pin waveform on the LTC3901 looks fine when LP=10mH…so why does it malfunction?
LTC3723 datasheet:
https://www.analog.com/media/en/technical-documentation/data-sheets/372312f.pdf
LTC3901 datasheet:
https://www.analog.com/media/en/technical-documentation/data-sheets/3901f.pdf
  • Full Bridge _Sync Rects_1.pdf
  • Full Bridge _Sync Rects_1.txt
saturation for too low Lp ... ? you need to look at the pri current and Vout of the signal Tx ....
Reactions: treez
    T
Thanks, sorry i should have clarified that this is only something in the LTspice simulation, (which doesnt give saturation in inductors) there is , as yet, no real circuit.
I actually believe this is a fault of the LTC3901 model in the LTspice simulator….in the attached LTspice sim, the sync rects work well after t=3ms….but don’t work up to t=1ms.
..This is in spite of the SYNC signal being exactly the same in each of those cases.
  • Full Bridge _Sync Rects_2.pdf
  • Full Bridge _Sync Rects_2.txt
Have all the other pins risen to their steady state value? Did you consider it may be trying to accurately simulate startup time of internal circuitry?
And did you check the part's test fixture in LTSpice?
Reactions: treez
    T
Thanks,
The LTspice test fixture of LTC3901 is receiving an idealised SYNC signal, and doesn’t have the sense pins connected. Also, its driven by an open loop simulation, so it cant be used with switched loads, which are needed to test out sync rect operation.
Yes i waited for steady state.
The attached ltspice sim of LTC3901 ("_3")again does not work correctly…the sync rect gates are badly driven in spite of the SYNC signal being of an acceptable form.
Also, at t=1ms, there is a high voltage spike on the drain of the sync rect fets (during full_load to no_load)……this would not be acceptable in a real circuit.
I cannot see it being possible to spend money on even a prototype of this if the sim cant be gotten working…..i think it’s a golden rule that a working sim is meaningless…but if a sim cannot be made to work, then it definitely won’t work on the bench.
Another point is that the LTC3901 model in ltspice doesn’t regulate the CSX+ pins to 11v like it should. Also, the calculations on page 9 of its datasheet lead to a negative value of resistance for RCSX2.
LTC3901
The attached version ("_4") has the sync fets being switched properly. This was achieved by idealising the drive voltages, and grouunding all the current sense inputs.
Withouut current sense of course, there are unacceptably large overvoltage spikes on the sync rect fet drains.
The attached (“_5”) ltspice sim of LTC3901 has the sync rects being switched correctly during heavy load.
However, during full-load-to-no-load, it suffers a massive & damaging voltage spike to the sync fet. This is because the only way I could get the sync fets switching correctly was to divide down the secondary sensed current signal into the LTC3901…(aswell as idealising all the drive voltages) …dividing it down so much that there is large current reversal in light load, resulting in bad voltage spiking to the sync fet.
I suspect the LTC3901 datasheet is dubious anyway……since the datasheet talks about allowing the current to reverse in light load…..whereas this is always bad news in the full bridge topology…because it results in high voltage spikes when the sync fet is turned off when reverse current is flowing through it.
The LTC3901 datasheet page 9 also states that the CSX+ pins are clamped to 11V with a clamp sink that’s “5mA minimum” in capability. This must mean “maximum” not “minimum”.
I am wondering how this part works on the bench? The low 10.5mV sense threshold on the LTC3901 suggests vulnerability to noise problems. And the part cant stop reverse current flowing in the sync fets….or rather it only stops reverse current flowing when its actually already flowing……ie too late….which is going to give potentially damaging voltage spikes on the SRs………Also, the sense threshold is 10.5mV…..so with a 2 milliohm rdson fet, that’s over 5 Amps of reverse current that can flow before it turns off….hmmmm
Does anyone have data of this part working on the bench?
  • Full Bridge _Sync Rects_3.pdf
  • Full Bridge _Sync Rects_3.TXT
  • Full Bridge _Sync Rects_4.txt
  • Full Bridge _Sync Rects_4.pdf
  • Full Bridge _Sync Rects_5.pdf
  • Full Bridge _Sync Rects_5.txt
