shaiko
Advanced Member level 5
Following my prior posts about making an asynchronous design synchronous - I implemented a ring oscillator on the Actel IGLOO FPGA. the results are rather strange.
This is my hardware :
The output is a nice trapezoidal waveform but for some reason changing the "chain_width" generic (from 50 to 150) had no effect on the generated clock's frequency(!)
Modifyng the code by adding additional T flip - flops did however divide the frequency further.
Any ideas ?
library ieee ;
use ieee.std_logic_1164.all ;
use ieee.numeric_std.all ;
entity ring_oscillator is
generic
chain_width : natural range 1 to 1000 := 50 -- must be an even number
port
RESET_I : in std_logic ;
RING_OSCILLATOR_GENERATED_CLOCK_O : buffer std_logic
end entity ring_oscillator ;
architecture synthesizable_ring_oscillator of ring_oscillator is
signal chain : unsigned ( chain_width downto 0 ) ;
attribute syn_keep: boolean;
attribute syn_keep of chain : signal is true;
begin
logic_chain : for i in 1 to chain_width
generate
chain ( i ) <= chain ( i - 1 ) ;
end generate;
chain ( 0 ) <= not chain ( chain_width ) or ( not RESET_I ) ;
t_flip_flop : process ( RESET_I , chain ( 0 ) )
begin
if RESET_I = '0' then
RING_OSCILLATOR_GENERATED_CLOCK_O <= '0' ;
elsif rising_edge ( chain ( 0 ) ) then
RING_OSCILLATOR_GENERATED_CLOCK_O <= not RING_OSCILLATOR_GENERATED_CLOCK_O ;
end if ;
end process t_flip_flop ;
end architecture synthesizable_ring_oscillator ;
Any ideas ?
