Never heard of it, probably it doesn't.In Altera Quartus there is an alternative to a wrapper.
You can define "virtual pins", and then you can have more pins than the physical device.
I don't know if Xilinx has the same possibility.
OK, probably there's something I don't undestand. But sure as hell they did use some kind of top-level interface in their project.i hv exactly followed d architecture n datapath given in d ieee paper
A Highly Efficient Cipher Processor for Dual-Field
Elliptic Curve Cryptography
This only solves the compilation problem. You still need a wrapper if you want to download the design into a device.
With virtual pins you can compile a sub-block as a Quartus top-level entity, even if it has "too many" pins. This is good for large designs when you don't want to compile the whole design every time.
You use Tcl commands like this:
set_instance_assignment -name VIRTUAL_PIN ON -to my_pin
Read more in page 15-11 in volume 2 of the Quartus II Handbook:
https://www.altera.com/literature/hb/qts/qts_qii5v2.pdf
Here are a few lines from the chapter:
"Virtual Pins
Usually, when you compile a design in the Quartus II software, all I/O ports are mapped directly to pins on the targeted device. However, you may not want to map all I/O ports to the device pins; use the Virtual Pin assignment then.
A virtual pin is an I/O element that you do not intend to connect to the chip pins. You create a virtual pin by assigning the Virtual Pin logic option to an I/O element. When you compile a design with some I/O elements assigned as virtual pins, those I/O elements become mapped to a logic element and not to a pin during compilation, and are then implemented as a LUT. You might use virtual pin assignments when you compile a partial design, because not all the I/Os from a partial design may drive chip pins at the top level."
