smqasim
Newbie level 6
voting system using 7 segments
Design a digital circuit of an electronic voting system that will be used in senate., which consists of 200 members. Each member has two switches, SW1 and SW2. SW1 is used to indicate that the member is present at the session. Each member in attendace turns this switch ON, thus sending a 5V signal to the main podium. When the member is absent, the signal at the podium is 0V. A YES vote, recorded by throwing the second switch, sends 5 V on the line to the podium, and a NO vote puts 0V on the line at the podium.
The output is composed of three single LEDS that indicate the result of the vote, YES, TIE or NO. In addition, three 7-segment LED displays indicate the number of members voting.
The chairman of the senate, who stays at the podium, has one switch, which is used to disable the circuit. When all the members have voted either YES or NO, the chairman of the senate throws the podium switch to ON, which latches the results into the display. Once the switch is thrown ON, further vote changes do not change the results that have been latched into the display.
Any hint to solve this problem.
