leonardo0
Junior Member level 3
Hi to forum
I want to make fm modulation to a 1.7 to 1.8 ghz pll . For this purpose i used adf4106 pll with umc vco . I though to drive the reference with dds signal at 40 mhz . My question is how to make fm modulation for fm bradcast signal . I can fm modulate the dds reference so this multiplied produces the needed 1.8 ghz fm modulation .
By running adisim i show i must use 1 mhz loop badwidth so gain in linear from 0 to 56 khz .
The problem is phase which has 80 degrees deviation at 56 khz from 0 degrees at 1 khz .
Will this confuse stereo emmisions since the pilot at 19 khz will be in different phase than the 38 khz subcarrier ?. Finally rds will have problems if i phase lock it to 19 khz ?.
Can someone enlighten me ?
