kapurk
Newbie level 5
I have a strange problem. I am working on an ac power adapter design for a 90W laptop charger based on the 3842 controller. I have 2 identical boards from different sources. One of them is the original chinese pcb (average quality laminate) and the other is (supposedly) a higher quality FR4 pcb which is a clone of the chinese pcb. THe problem is that the flyback transformer in the chinese pcb does not heat up beyond 80degC but the same transformer in the clone board heats up to 120degC or more. Both boards have identical parts. I have even tried swapping the parts from one to the other but the transformer always heats up in the clone board. I have checked the switching waveforms on both boards and they are identical.
I have gone to the extent of cutting the boards in half to mix and match the primary section from one with the secondary section of the other. The problem seems to be on the primary/auxiliary winding side because the transformer always heats up with the primary side from the clone board. I have spent a whole week trying to figure out the reason by modifying the snubber, changing the diodes, mosfet, ... but the heating does not stop. At the same time no matter what I do to the chinese board the transformer does not heat up on that board. Note that it is not just one transformer that I am talking about. I have tried this with a whole set of identical transformers and boards.
Any ideas? Anyone?
Any ideas? Anyone?
