T
treez
Hello,
Our LT3799 based 15W Flyback PFC converter is giving an output which is rippling from 36V to 44V. (at 100Hz)
Since the output voltage goes above 42V (42V is the SELV level), does this mean that it is too dangerous to allow semi-skilled test technicians to work on it?
Does touching 44V in one hand and ground on the other mean you die from electrocution, because its above the 42V SELV level?
Does touching 41V in one hand and ground on the other mean you don't die from electrocution, because its below the 42V SELV level?
