flipped voltage follower
jutek
Full Member level 4
hello
how to make the flipped voltage follower with nmos input gain close to 1?
the opposite one, from the picture gives me 1V/V gain and with nmos input gives me about 0.7V/V I want to build complementary buffer with that.
regards
the picture is here:
flipped-voltage-follower
You can go through the following slides :
In slides 21 and later, rail-to-rail output buffer stages are described using flipped voltage follower
(using both NMOS and PMOS).
Hope that helps..
Bharath
flipped-volatge-follower
hi, thanks for the paper
unfortunately i can't find the mistake, the buffer's gain is still far from 1.
maybe it's not suitable for low 1.3V supplies? the fact is it attenuates input voltage.
did someone design this buffer?
regards
