Flicker noise in FETs
diarmuid
Full Member level 2
Full Member level 2
Dublin, Ireland
Hello All,
2 quick questions on flicker noise in FETs:
1. Which region exhibits lower flicker noise - triode or saturation?
2. Does flicker noise exhibit a dependancy on Vov?
Thanks,
Diarmuid
Generally flicker noise tends to rise with Vov, see the following snippet. Hence triode region (large Vov, small Vds) will probably exhibit more flicker noise than saturation region. Still, operation in strong inversion mode (with large Vov and large Vds) would probably exhibit even more flicker noise in saturation region.
View attachment Binkley__p213.pdf. There's a lot more about flicker noise in this book.
Very interesting that. Excellent book it seems. Ill be running a few sims over the next week or so so will update this with
some general results I get.
some general results i have seen from simulation:
- flicker noise appears to decrease with increasing area
- triode region exhibits worse flicker noise
- PMOS appears to exhibit less flicker noise than NMOS
- one additional observation
- flicker noise is much less in subthreshold than saturation
