fixed point multiplier
sheikh
fix point multiplier
Hello Dears
Is it possible to give me a link that contains vhdl code for a 32 bit fix point multiplier ?(I mean, 32bits inputs and 32 bits output)
(also it must be synthesizable )
Regard
Mostafa
mrflibble
Advanced Member level 5
Just use an expression like "a*b".
TrickyDicky
Wow - thats also my favourite too MrFlibble.
sheikh
Ha haa:) when I read it again, I got surprised! because I forget to sent the main question. any way, Let me correct it, how can I coding the attached file just by using (*). Is there any way that the result of synthesis be same as using mux and multiplier directly. may be you say "use the "Process" "but, the result of synthesis have extera units.
Regards
Mostafa
TrickyDicky
This code is exactly whats in your diagram.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
signal mult_result : unsigned(63 downto 0);
process(clk)
  variable mult_ip1, mult_ip2 : unsigned(31 downto 0);
begin
  if rising_edge(clk) then
    --Mux1
    if sel0 = '0' then mult_ip1 := ip0;
    else               mult_ip1 := ip1;
    end if;
    --mux2
    if sel1 = '0' then mult_ip2 := ip2;
    else               mult_ip2 := ip3;
    end if;
    --Multiplier and register in one line!
    if load = '1' then
      mullt_result <= mult_ip1 * mult_ip2;
    end if;
  end if;
end process;
sheikh
Thanks TrickyDicky
mrflibble
Indeed, and I wasn't even joking. :p Quite often you don't need to make it more complicated than that, as exemplified by your central line of code:
 mult_result <= mult_ip1 * mult_ip2; --- minus the typo of mullt_result vs mult_result ;-)
Reactions: sheikh
    sheikh
sheikh
Thanks Dear mrflibble, I agree with you:))
