epocaliptic
So here is my code, this is the first thing I've done in verilog so take it easy on me if you can. I'm getting an error in quartus that states:
Error (10200): Verilog HDL Conditional Statement error at clock.v(12): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct.
here is my code.
Am I also on the right track if I want to synchronize a 50mhz clock to seconds?
By the way I know nothing is set to the outputs yet, I'll do that later.
Thank you for your time.
here is my code.
module clock(clk,reset,KEY0,KEY1,sec,min,hour);
input KEY0,KEY1,clk,reset;
output sec,min,hour;
//assuming clock is 50 mhz, so 1000mhz=1khz, and 1khz is 1 second, so 50 mhz=50,000 khz.
reg [15:0] clk_counter;
reg[5:0] seconds_counter;
reg[5:0] min_counter;
reg[4:0] hour_counter;
always @(posedge clk or posedge reset)
begin
if (reset || hour_counter==5'b11000) //reset entire clock to zero with reset or with when clock hits 24
begin
clk_counter=16'b0000000000000000;
seconds_counter=6'b000000;
min_counter=6'b000000;
hour_counter=5'b000000;
end
else if (min_counter==6'b110001 && seconds_counter==6'b110001)//incrementing hours at 59 minutes and 59 seconds
begin
hour_counter=hour_counter + 1;
end
else if (seconds_counter==6'b110001)//incrementing minutes at 59 seconds
begin
min_counter=min_counter + 1;
end
else if (clk_counter==16'b1100001101001111)//49,999 in binary, should increment seconds and then reset the counter.
begin
seconds_counter= seconds_counter + 1;
end
else
begin
clk_counter<= clk_counter + 1;
end
end
endmodule
