First real verilog program, synchronizing clock to seconds.
epocaliptic
So here is my code, this is the first thing I've done in verilog so take it easy on me if you can. I'm getting an error in quartus that states:
Error (10200): Verilog HDL Conditional Statement error at clock.v(12): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct.
here is my code.
Am I also on the right track if I want to synchronize a 50mhz clock to seconds?
By the way I know nothing is set to the outputs yet, I'll do that later.
module clock(clk,reset,KEY0,KEY1,sec,min,hour);
	input KEY0,KEY1,clk,reset;
	output sec,min,hour;
	//assuming clock is 50 mhz, so 1000mhz=1khz, and 1khz is 1 second, so 50 mhz=50,000 khz.
	reg [15:0] clk_counter;
	reg[5:0] seconds_counter;
	reg[5:0] min_counter;
	reg[4:0] hour_counter;
	always @(posedge clk or posedge reset)
	begin
		if (reset || hour_counter==5'b11000) //reset entire clock to zero with reset or with when clock hits 24
		begin
			clk_counter=16'b0000000000000000;
			seconds_counter=6'b000000;
			min_counter=6'b000000;
			hour_counter=5'b000000;
		end
		else if (min_counter==6'b110001 && seconds_counter==6'b110001)//incrementing hours at 59 minutes and 59 seconds
		begin
			hour_counter=hour_counter + 1;
		end
		else if (seconds_counter==6'b110001)//incrementing minutes at 59 seconds
		begin
			min_counter=min_counter + 1;
		end
		else if (clk_counter==16'b1100001101001111)//49,999 in binary, should increment seconds and then reset the counter.
		begin
			seconds_counter= seconds_counter + 1;
		end
		else
		begin
			clk_counter<= clk_counter + 1;
		end
	end
endmodule
Thank you for your time.
Try to split if (reset || hour_counter==5'b11000) on 2 branches, because used asinc reset:
if (reset) //reset
		begin
		end
else if (hour_counter==5'b11000)
		begin
		end
thanks for your response poluekt,
but even if I take out the reset entirely and just leave (hour_counter==5'b11000) I still get the error.
For sequential logic use non-blocking assignment <= instead blocking assignment =
oh yes, I forgot to do that for most of them, thank you for reminding me.
But I don't think it will fix the error that I am getting in the if statement.
got it working, thank you poluekt when i split it up into two if statements it seemed to work!
