did you look at it with thermal camera?...see if anything getting hot...there is a good therm cam you can buy for £150...ask me and i will tell you part number.
otherwise, strip it down and see what you can get working....eg disconnect components and give the FAN6754 a dc bias voltage from external supply then see.
....take off output diode....shove vout on it with an ext psu...and see if their is output short circuit...etc etc...
maybe one of the aux caps is dry...replace all.
