The basis of good design is good tools and good parameters.
We have some wafers with the PCM (process control module) between the dice. I want to extract parameters from those, for checks.
What is the best way to generate simple but efficient models ?
What is the good software ? UtMos?
What are the good measurements ? with what kind of tools ?
I used IC-CAP for both bjt and mos. Worked OK, real easy to use with nice tutorials and pre-setup extractions. It's made by agilent, so it's set up to run 4145, etc, automatically.
One note - you need a 4145, or other semiconductor parametric analyzer. Or do it by hand with a curve tracer, but that's no good for modelling.
