Explain #define SWITCH_PRESSED (bit) 1 in C
Help
Advanced Member level 2
Hi...
Anyone help me to explain this #define SWITCH_PRESSED (bit) 1??
Is it define the switch_pressed is High??
Thanks.....
C (#define)
Means that when you used the keywords SWITCH_PRESSED it will return a 1 or gives a one.
    Help
Re: C (#define)
#defines are just text substitutions :)
So whenever you write SWITCH_PRESSED the preprocessor will replace it with (bit) 1 before passing it to the compiler.
Simple but powerful ...
best regards
    Help
