experience in fpga programming
mc&fpga
Member level 1
how can i configure a fpga like xc2s with pci,any idea or where can i find
more file or relative circuit.
zhuoyue
Newbie level 6
why you want configure fpga with pci ,it too complex i think,why not with easy methods?
tlp71@hotmail.com
Full Member level 4
you need to use a pci bridge, in this mode you can use pci signal converted in add and data signal and use any kind of download mode.
Bye.
G.
mc&fpga
Member level 1
Bye.
G.
please say some more information or do you have any document about it.
or do you have any experience in this field.
tlp71@hotmail.com
Full Member level 4
try to search at www.quicklogic.com, they make pci bridge, from one side you have a pci interface, from the other side you have a data and address bus as we use normally.
After, depending whic device you wuld program, if you use a spartan as xilinx you need to implement a serial protocol using bus, otherwise you can use directly the bus.
Good luck
G.
mc&fpga
Member level 1
Good luck
G.
yes i want to configure spartan ll in slave serial mode, how can i use the bus,
Git
Full Member level 4
Torino
Why can't you use an ordinary parallel port JTAG cable?
Git
Ohh
Member level 2
If you want to configure an FPGA device via PCI bus, you must have a PCI controller that manages the PCI interface + software driver.
mc&fpga
Member level 1
it means that i should use a pci controller (ic)
but i want to configure ic that itself contain pci controller,the program
of xc2s is pci bus controller,
ok,
another problem if i have 2 xc2s in my board and one of them pci bus controller and another one contain some program that change between
processing data can i configure the another xc2s with software by the xc2s consist of pci bus controller
do you know how i can configure xc2s with other (not in daisy chain)
