mc&fpga
how can i configure a fpga like xc2s with pci,any idea or where can i find
more file or relative circuit.
please say some more information or do you have any document about it.tlp71@hotmail.com said:you need to use a pci bridge, in this mode you can use pci signal converted in add and data signal and use any kind of download mode.
Bye.
G.
yes i want to configure spartan ll in slave serial mode, how can i use the bus,tlp71@hotmail.com said:f you use a spartan as xilinx you need to implement a serial protocol using bus, otherwise you can use directly the bus.
Good luck
G.
it means that i should use a pci controller (ic)Ohh said:If you want to configure an FPGA device via PCI bus, you must have a PCI controller that manages the PCI interface + software driver.
