Hi Brian,
Thank you for the quick reply.
I tried in both ways, also set up my IP address for my network.
I checked my router, there is no MAC address blacklisted.
I have only 1 alert message from Proteus while simulating which says "Simulation is not running in real time due to excessive CPU load."
Would it be possible that this is causing me this issue?
If not the only thing what I can think of is that Proteus is unable to get connection with my LAN card through WINCAP
Just to clarify.
#define STATIC 0
- On the console it gives me a DHCP Failed message, and the IP, GW, DNS are 0.0.0.0
#define STATIC 1
- On the console it gives me back the IP and the GW what I defined, however the DNS comes back with 0.0.0.0, and the simulation is unavailable through the web-browser.
