tarkyss
Full Member level 6
ld command gcc
I used the example
h**p://www.asic-world.com/verilog/pli2.html#Modelsim
but when i run
gcc -c -g -I$MODEL/include pli_full_example_modelsim.c
there are a warning
hello_vpi_modelsim.c: In function `registerHelloSystfs':
hello_vpi_modelsim.c:9: warning: assignment from incompatible pointer type
then i run
ld -shared -E -o pli_full_example.sl pli_full_example_modelsim.o
it is said ther are no -shared and -E parameter, I check my ld, my ld has not the two parameters
then i dont user -shared and -E, used ld -o only
but it display
vpi_printf and vpi_register_systf are not defined
even i excute
cat /user/modelsim6.1a/modeltech/include/vpi_user.h >> hello_vpi.c
it still display
why
i try my own code, running gcc, there is no warning, but when running ld it cannot work yet,
in my code srand and rand function is used
so it said srand is not defined
thanks
I used the example
but when i run
there are a warning
then i run
but it display
even i excute
it still display
why
thanks
