Hello,
I am working with TSMC 65nm, and I got a problem while running the PEX. After I have extracted the parasitics and PEX worked well. When I tried to include the calibre file in the schematic file to run the post layout simulation I got this error:
ERROR (OSSHNL-514): Netlisting failed due to errors reported before. Netlist may be corrupt or may not be produced at all. Fix reported errors and netlist again....unsuccessful.
and the simulation doesn't run :???:
Addition:
These are the errors that are reported:
ERROR (OSSHNL-249): There is no corresponding terminal for 'Vin+' (on placed master 'GM_Q1/symbol') in
switch master 'GM_Q1/calibre'. Netlisting will continue if this terminal can be
ignored. Otherwise, ensure that you have a corresponding terminal in switch
master and netlist again.
ERROR (OSSHNL-249): There is no corresponding terminal for 'Vin-' (on placed master 'GM_Q1/symbol') in
ERROR (OSSHNL-249): There is no corresponding terminal for 'Vout+' (on placed master 'GM_Q1/symbol') in
ERROR (OSSHNL-249): There is no corresponding terminal for 'Vout-' (on placed master 'GM_Q1/symbol') in
