error maxplus II: help me.
ktnha
Newbie level 2
viet nam
I write code with maxplus II version 10.2:
architecture rtl of sys is
type regtype is array(0 to M-1) of wrdtype;
signal REG: regtype;
signal RW: std_logic_vector(1 downto 0);
begin
process(...)
begin
for j in 0 to M-1 loop
line 32: REG(j) <= (REG(j)'range => '0');
end loop;
end process;
end rtl.
when compiler, i see error:
Error: line 32: Unsupported feature error: aggregates are supported only types that map to an array of bits.
this my files:
Re: error: help me.
Try to replace the for-statement with:
reg <= (others => (others => '0'));
Maybe this can be synthesized by MaxPlusII. If this does not solve your issue, can you upgrade to QuartusII software? I am pretty sure QuartusII supports both constructs.
Devas
error: help me.
reg <= (others =>(others => '0'));
I don't solve my issue. I must to use maxplus for my design.
please, help me.
