ERROR -- Incorrect number of interface nodes for XIS PSPICE
unkukaracha
Newbie level 2
error -- incorrect number of interface nodes for
dear all,i`m having problem with my PSPICE program.its state ERROR -- Incorrect number of interface nodes for XIS...here is my program
* ingold=0 post probe
*+ absmos=1e-15 dcstep=1000 nopiv
*+ absv=1e-15 relv=1e-12 absi=1e-15
*+ gmindc=1e-24 itl1=1000 converge accurate
*+ method=gear lvltim=2 itl5=10000 delmax=1e-15
*+ dv=0.2
.PARAM
+ k=1.38e-23 T=300 eps0=8.85e-12
+ Ka=15.8 Kb=63.1e-9 Kn=1e-10
+ Nsil=3.0e18 Nnit=2.0e18
+ Cbulk=0.1
* Beginning of the sub-circuit definition
.SUBCKT ISFET 6 1 3 4 101
*[drain] [ref.el] [source] [bulk] [pH input]
+ q=1.6e-19 NAv='6.023e23*1e3'
+ epsw=78.5 epsihp=32 epsohp=32
+ dihp=0.1n dohp=0.3n Cbulk=0.1
+ Eabs=4.7 Phim=4.7 Erel=0.200 Chieo=3e-3 Philj=1e-3
+ ET='q/(k*T)'
+ sq='sqrt(8*eps0*epsw*k*T)'
+ Cb='NAv*Cbulk'
+ KK='Ka*Kb'
+ Ch='((eps0*epsihp*epsohp)/(epsohp*dihp+epsihp*dohp))'
+ Cd='(sq*ET*0.5)*sqrt(Cb)'
+ Ceq='1/(1/Cd+1/Ch)'
Eref 1 10 VOL='Eabs-Phim-Erel+Chieo+Philj'
Ceq 10 2 C='1/(1/Cd+1/Ch)'
EP1 46 0 VOL='log(KK)+4.6*V(101)'
RP1 46 0 1G
EP2 23 0 VOL='log(Ka)+2.3*V(101)'
RP2 23 0 1G
EPH 2 10 VOL='(q/Ceq)*(Nsil*((exp(-2*V(2,10)*ET)-exp(V(46)))/(exp(-2*V(2,10)*ET)
+exp(V(23))*exp(-1*V(2,10)*ET)+exp(V(46))))+ Nnit*((exp(-1*V(2,10)*ET))/(exp(-1*V(2,10)*ET)+(Kn/Ka)*exp(V(23)))))'
RpH 101 0 1K
MIS 6 2 3 4 MISFET L=18u W=804u NRS=5 NRD=5
.MODEL MISFET NMOS LEVEL=2
+ VTO=7.99E-01 LAMBDA=7.59E-03 RSH=3.5E+01 TOX=86E-9
+ UO=6.53E+02 TPG=0
+ UEXP=7.64E-02 NSUB=3.27E+15 NFS=1.21E+11
+ NEFF=3.88 VMAX=5.35E+04 DELTA=1.47 LD=2.91E-06
+ UCRIT=7.97E+04 XJ=6.01E-09 CJ=4.44E-4 IS=1E-11
+ CJSW=5.15E-10 PHI=5.55E-01 GAMMA=9.95E-01
+ MJ=0.395 MJSW=0.242 PB=0.585
.ENDS ISFET
* sssssssssssssssssssssssssssssssssssssssssssss
* Beginning of the example circuit
XIS 100 1 3 3 200 ISFET
Vbias 1 0 DC 1.5
VpH 200 0 DC 10
Vd 101 0 DC 1.5
Vid 101 100 DC 0
.OP
.DC Vbias 0.0 4.0 0.1
.PRINT DC V(1,XIS.2) V(XIS.2,0) V(XIS.23) V(XIS.46) V(1) I(Vid)
.PROBE
.END
can somebody please help me to solve this problem
Your subcircuit definition appears to be sitting in
the middle of your .param section, see a bunch of
+param=value
lines follow the .subckt definition and the parser is
probably appending these to the .subcircuit node
list (making it > 5 nodes).
I think if you untangle the two it'll be OK.
Re: ERROR -- Incorrect number of interface nodes for XIS PS
but how to entangle the parameter nodes?
