Hello friends,
I have RTL design with me which I have synthesized using DC and created gate-level netlist. I have to simulate this gate-level netlist with the cell library and testbench in Modelsim. The issue is I only have a.lib file with me and not a .vhd file of library with me .
I did the following in Library compiler
read_lib saed90nm_typ.lib(this will create saed90nm_typ.db)
write_lib –f vhdl –o saed90nm_typ.vhd (the .vhd will be use by Modelsim)
The write_lib command generates 3 different .vhd files 1] saed90nm_typ_vtables.vhd 2] saed90nm_typ_components.vhd 3] saed90nm_typ_VITAL.vhd for me. I tried using all 3 of them but I am unable to simulate my gate-level netlist with those files as they are throwing errors .
Can any1 help me solving this problem ?
Also if possible can any one attach saed90nm_typ.vhd file here, I am asking as I am assuming its a fairly commonly used library , that will be a great help .
Thanks in advance !
