error:HDLCompilers:217 in verilog code synthesis
jameela
Junior Member level 2
Pakistan
error:HDLCompilers:217 Integer constant '10101010101010101010101010101010' is too large to represent in 32 bits
help me to remove it
module inter1(out1,ins1,inp,inclk,clr,outclk);
input inclk,clr,ins1,outclk;
output inp,out1;
//wire [31:0]s1;
reg [31:0]s2;
integer s1;
reg ins;
reg [1023:0]out,out1;
reg [1024:1] inp;
parameter a=1 ,b=3*a ,c=b-1;
initial
s1<={10101010101010101010101010101010};
always@(posedge outclk)
begin
if (ins1==0)
s2<=~s1;
else
s2<=s1;
end
always@(posedge inclk )
begin
if(clr) inp<=0;
else
begin
inp[1024:2]<=inp[1023:1];
inp[1]<=s2;
end
#32;
end
output inp,out1;
//wire [31:0]s1;
reg [31:0]s2;
integer s1;
reg ins;
reg [1024:1] inp;
parameter a=1 ,b=3 ,c=2;
initial
s1<={10101010101010101010101010101010}; //remove this line and replace with
s1<=32'b0101010101010101010101010101010;
begin
if (ins1==0)
s2<=~s1;
else
s2<=s1;
end
begin
if(clr) inp<=0;
else
begin
inp[1]<=s2;
end
#32;
end
    jameela
it solved my above prob
i have few more questions about the code given below
1) on simulating this code s21 gives 32'b 10101010101010101010101010101010 when ins==0 and gives 32'b 01010101010101010101010101010101 when ins==1
however it should be vice versa as given in code ...why is it so??
2) s21 then goes to inp which is a serial to parallel shiftreg but only a few bits are shifted properly into it at every clock edge and after that the waveform flattens out whereas it should show shifting of all bits properly...how could it be corrected?
3) when i implemented this code it gave following errors:
Total Number of 4 input LUTs: 7 out of 9,312 1%
Number used as logic: 6
Number used as Shift registers: 1
Number of bonded IOBs: 2,084 out of 232 898% (OVERMAPPED) IOB Flip Flops: 987
Number of bonded Out/Bidir IOBs: 2,080 out of 176 1181% (OVERMAPPED) Number of bonded Input IBUFs: 4 out of 56 12%
Number of GCLKs: 2 out of 24 8%
module inter1(s21,out1,ins1,inp,inclk,clr,outclk);
output inp,out1,s21;
reg [31:0]s2,s1,s21;
reg ins;
reg [1024:1] inp;
initial
s1<=32'b 10101010101010101010101010101010;
begin
if (ins1==1)
begin
s2<=s1;
s21<=s2;
end
else
begin
s2<=~s1;
s21<=s2;
end
end
begin
if(clr) inp<=0;
else
begin
inp[1]<=s21;
end
#32;
end
always@(posedge outclk or posedge clr)
begin
if(clr)out<=0;
else
begin
out[0]<=inp[576];
out[1]<=inp[96];
out[2]<=inp[640];
out[3]<=inp[160];
out[4]<=inp[704];
out[5]<=inp[224];
out[6]<=inp[768];
out[7]<=inp[288];
out[8]<=inp[832];
out[9]<=inp[352];
out[10]<=inp[896];
out[11]<=inp[416];
out[12]<=inp[960];
out[13]<=inp[480];
out[14]<=inp[1024];
out[15]<=inp[544];
out[16]<=inp[64];
out[17]<=inp[608];
out[18]<=inp[128];
out[19]<=inp[672];
out[20]<=inp[192];
out[21]<=inp[736];
out[22]<=inp[256];
out[23]<=inp[800];
out[24]<=inp[320];
out[25]<=inp[864];
out[26]<=inp[384];
out[27]<=inp[928];
out[28]<=inp[448];
out[29]<=inp[992];
out[30]<=inp[512];
out[31]<=inp[32];
out[32]<=inp[482];
out[33]<=inp[2];
out[34]<=inp[546];
out[35]<=inp[66];
out[36]<=inp[610];
out[37]<=inp[130];
out[38]<=inp[674];
out[39]<=inp[194];
out[40]<=inp[738];
out[41]<=inp[258];
out[42]<=inp[802];
out[43]<=inp[322];
out[44]<=inp[866];
out[45]<=inp[386];
out[46]<=inp[930];
out[47]<=inp[450];
out[48]<=inp[994];
out[49]<=inp[514];
out[50]<=inp[34];
out[51]<=inp[578];
out[52]<=inp[98];
out[53]<=inp[642];
out[54]<=inp[162];
out[55]<=inp[706];
out[56]<=inp[226];
out[57]<=inp[770];
out[58]<=inp[290];
out[59]<=inp[834];
out[60]<=inp[354];
out[61]<=inp[898];
out[62]<=inp[418];
out[63]<=inp[962];
out[64]<=inp[638];
out[65]<=inp[158];
out[66]<=inp[702];
out[67]<=inp[222];
out[68]<=inp[766];
out[69]<=inp[286];
out[70]<=inp[830];
out[71]<=inp[350];
out[72]<=inp[894];
out[73]<=inp[414];
out[74]<=inp[958];
out[75]<=inp[478];
out[76]<=inp[1022];
out[77]<=inp[542];
out[78]<=inp[62];
out[79]<=inp[606];
out[80]<=inp[126];
out[81]<=inp[670];
out[82]<=inp[190];
out[83]<=inp[734];
out[84]<=inp[254];
out[85]<=inp[798];
out[86]<=inp[318];
out[87]<=inp[862];
out[88]<=inp[382];
out[89]<=inp[926];
out[90]<=inp[446];
out[91]<=inp[990];
out[92]<=inp[510];
out[93]<=inp[30];
out[94]<=inp[574];
out[95]<=inp[94];
out[96]<=inp[420];
out[97]<=inp[964];
out[98]<=inp[484];
out[99]<=inp[4];
out[100]<=inp[548];
out[101]<=inp[68];
out[102]<=inp[612];
out[103]<=inp[132];
out[104]<=inp[676];
out[105]<=inp[196];
out[106]<=inp[740];
out[107]<=inp[260];
out[108]<=inp[804];
out[109]<=inp[324];
out[110]<=inp[868];
out[111]<=inp[388];
out[112]<=inp[932];
out[113]<=inp[452];
out[114]<=inp[996];
out[115]<=inp[516];
out[116]<=inp[36];
out[117]<=inp[580];
out[118]<=inp[100];
out[119]<=inp[644];
out[120]<=inp[164];
out[121]<=inp[708];
out[122]<=inp[228];
out[123]<=inp[772];
out[124]<=inp[292];
out[125]<=inp[836];
out[126]<=inp[356];
out[127]<=inp[900];
out[128]<=inp[700];
out[129]<=inp[220];
out[130]<=inp[764];
out[131]<=inp[284];
out[132]<=inp[828];
out[133]<=inp[348];
out[134]<=inp[892];
out[135]<=inp[412];
out[136]<=inp[956];
out[137]<=inp[476];
out[138]<=inp[1020];
out[139]<=inp[540];
out[140]<=inp[60];
out[141]<=inp[604];
out[142]<=inp[124];
out[143]<=inp[668];
out[144]<=inp[188];
out[145]<=inp[732];
out[146]<=inp[252];
out[147]<=inp[796];
out[148]<=inp[316];
out[149]<=inp[860];
out[150]<=inp[380];
out[151]<=inp[924];
out[152]<=inp[444];
out[153]<=inp[988];
out[154]<=inp[508];
out[155]<=inp[28];
out[156]<=inp[572];
out[157]<=inp[92];
out[158]<=inp[636];
out[159]<=inp[156];
out[160]<=inp[358];
out[161]<=inp[902];
out[162]<=inp[422];
out[163]<=inp[966];
out[164]<=inp[486];
out[165]<=inp[6];
out[166]<=inp[550];
out[167]<=inp[70];
out[168]<=inp[614];
out[169]<=inp[134];
out[170]<=inp[678];
out[171]<=inp[198];
out[172]<=inp[742];
out[173]<=inp[262];
out[174]<=inp[806];
out[175]<=inp[326];
out[176]<=inp[870];
out[177]<=inp[390];
out[178]<=inp[934];
out[179]<=inp[454];
out[180]<=inp[998];
out[181]<=inp[518];
out[182]<=inp[38];
out[183]<=inp[582];
out[184]<=inp[102];
out[185]<=inp[646];
out[186]<=inp[166];
out[187]<=inp[710];
out[188]<=inp[230];
out[189]<=inp[774];
out[190]<=inp[294];
out[191]<=inp[838];
out[192]<=inp[762];
out[193]<=inp[282];
out[194]<=inp[826];
out[195]<=inp[346];
out[196]<=inp[890];
out[197]<=inp[410];
out[198]<=inp[954];
out[199]<=inp[474];
out[200]<=inp[1018];
out[201]<=inp[538];
out[202]<=inp[58];
out[203]<=inp[602];
out[204]<=inp[122];
out[205]<=inp[666];
out[206]<=inp[186];
out[207]<=inp[730];
out[208]<=inp[250];
out[209]<=inp[794];
out[210]<=inp[314];
out[211]<=inp[858];
out[212]<=inp[378];
out[213]<=inp[922];
out[214]<=inp[442];
out[215]<=inp[986];
out[216]<=inp[506];
out[217]<=inp[26];
out[218]<=inp[570];
out[219]<=inp[90];
out[220]<=inp[634];
out[221]<=inp[154];
out[222]<=inp[698];
out[223]<=inp[218];
out[224]<=inp[296];
out[225]<=inp[840];
out[226]<=inp[360];
out[227]<=inp[904];
out[228]<=inp[424];
out[229]<=inp[968];
out[230]<=inp[488];
out[231]<=inp[8];
out[232]<=inp[552];
out[233]<=inp[72];
out[234]<=inp[616];
out[235]<=inp[136];
out[236]<=inp[680];
out[237]<=inp[200];
out[238]<=inp[744];
out[239]<=inp[264];
out[240]<=inp[808];
out[241]<=inp[328];
out[242]<=inp[872];
out[243]<=inp[392];
out[244]<=inp[936];
out[245]<=inp[456];
out[246]<=inp[1000];
out[247]<=inp[520];
out[248]<=inp[40];
out[249]<=inp[584];
out[250]<=inp[104];
out[251]<=inp[648];
out[252]<=inp[168];
out[253]<=inp[712];
out[254]<=inp[232];
out[255]<=inp[776];
out[256]<=inp[824];
out[257]<=inp[344];
out[258]<=inp[888];
out[259]<=inp[408];
out[260]<=inp[952];
out[261]<=inp[472];
out[262]<=inp[1016];
out[263]<=inp[536];
out[264]<=inp[56];
out[265]<=inp[600];
out[266]<=inp[120];
out[267]<=inp[664];
out[268]<=inp[184];
out[269]<=inp[728];
out[270]<=inp[248];
out[271]<=inp[792];
out[272]<=inp[312];
out[273]<=inp[856];
out[274]<=inp[376];
out[275]<=inp[920];
out[276]<=inp[440];
out[277]<=inp[984];
out[278]<=inp[504];
out[279]<=inp[24];
out[280]<=inp[568];
out[281]<=inp[88];
out[282]<=inp[632];
out[283]<=inp[152];
out[284]<=inp[696];
out[285]<=inp[216];
out[286]<=inp[760];
out[287]<=inp[280];
out[288]<=inp[233];
out[289]<=inp[778];
out[290]<=inp[298];
out[291]<=inp[842];
out[292]<=inp[362];
out[293]<=inp[906];
out[294]<=inp[426];
out[295]<=inp[970];
out[296]<=inp[490];
out[297]<=inp[10];
out[298]<=inp[554];
out[299]<=inp[74];
out[300]<=inp[618];
out[301]<=inp[138];
out[302]<=inp[682];
out[303]<=inp[202];
out[304]<=inp[746];
out[305]<=inp[266];
out[306]<=inp[810];
out[307]<=inp[330];
out[308]<=inp[874];
out[309]<=inp[394];
out[310]<=inp[938];
out[311]<=inp[458];
out[312]<=inp[1002];
out[313]<=inp[522];
out[314]<=inp[42];
out[315]<=inp[586];
out[316]<=inp[106];
out[317]<=inp[650];
out[318]<=inp[170];
out[319]<=inp[714];
out[320]<=inp[886];
out[321]<=inp[406];
out[322]<=inp[960];
out[323]<=inp[470];
out[324]<=inp[1014];
out[325]<=inp[534];
out[326]<=inp[54];
out[327]<=inp[598];
out[328]<=inp[118];
out[329]<=inp[662];
out[330]<=inp[182];
out[331]<=inp[726];
out[332]<=inp[246];
out[333]<=inp[790];
out[334]<=inp[310];
out[335]<=inp[854];
out[336]<=inp[374];
out[337]<=inp[918];
out[338]<=inp[438];
out[339]<=inp[982];
out[340]<=inp[502];
out[341]<=inp[22];
out[342]<=inp[566];
out[343]<=inp[86];
out[344]<=inp[630];
out[345]<=inp[150];
out[346]<=inp[694];
out[347]<=inp[214];
out[348]<=inp[758];
out[349]<=inp[278];
out[350]<=inp[822];
out[351]<=inp[342];
out[352]<=inp[172];
out[353]<=inp[716];
out[354]<=inp[236];
out[355]<=inp[780];
out[356]<=inp[300];
out[357]<=inp[844];
out[358]<=inp[364];
out[359]<=inp[908];
out[360]<=inp[428];
out[361]<=inp[972];
out[362]<=inp[492];
out[363]<=inp[12];
out[364]<=inp[556];
out[365]<=inp[76];
out[366]<=inp[620];
out[367]<=inp[140];
out[368]<=inp[684];
out[369]<=inp[204];
out[370]<=inp[748];
out[371]<=inp[268];
out[372]<=inp[812];
out[373]<=inp[332];
out[374]<=inp[876];
out[375]<=inp[396];
out[376]<=inp[940];
out[377]<=inp[460];
out[378]<=inp[1004];
out[379]<=inp[524];
out[380]<=inp[44];
out[381]<=inp[588];
out[382]<=inp[108];
out[383]<=inp[652];
out[384]<=inp[948];
out[385]<=inp[468];
out[386]<=inp[1012];
out[387]<=inp[532];
out[388]<=inp[52];
out[389]<=inp[596];
out[390]<=inp[116];
out[391]<=inp[660];
out[392]<=inp[180];
out[393]<=inp[724];
out[394]<=inp[244];
out[395]<=inp[788];
out[396]<=inp[308];
out[397]<=inp[852];
out[398]<=inp[372];
out[399]<=inp[916];
out[400]<=inp[436];
out[401]<=inp[980];
out[402]<=inp[500];
out[403]<=inp[20];
out[404]<=inp[564];
out[405]<=inp[84];
out[406]<=inp[628];
out[407]<=inp[148];
out[408]<=inp[692];
out[409]<=inp[212];
out[410]<=inp[756];
out[411]<=inp[276];
out[412]<=inp[820];
out[413]<=inp[340];
out[414]<=inp[884];
out[415]<=inp[404];
out[416]<=inp[110];
out[417]<=inp[654];
out[418]<=inp[174];
out[419]<=inp[718];
out[420]<=inp[238];
out[421]<=inp[782];
out[422]<=inp[302];
out[423]<=inp[846];
out[424]<=inp[366];
out[425]<=inp[910];
out[426]<=inp[430];
out[427]<=inp[974];
out[428]<=inp[494];
out[429]<=inp[14];
out[430]<=inp[558];
out[431]<=inp[78];
out[432]<=inp[622];
out[433]<=inp[142];
out[434]<=inp[686];
out[435]<=inp[206];
out[436]<=inp[750];
out[437]<=inp[270];
out[438]<=inp[814];
out[439]<=inp[334];
out[440]<=inp[878];
out[441]<=inp[398];
out[442]<=inp[942];
out[443]<=inp[462];
out[444]<=inp[1006];
out[445]<=inp[526];
out[446]<=inp[46];
out[447]<=inp[506];
out[448]<=inp[1010];
out[449]<=inp[530];
out[450]<=inp[50];
out[451]<=inp[594];
out[452]<=inp[114];
out[453]<=inp[658];
out[454]<=inp[178];
out[455]<=inp[722];
out[456]<=inp[242];
out[457]<=inp[786];
out[458]<=inp[306];
out[459]<=inp[850];
out[460]<=inp[370];
out[461]<=inp[914];
out[462]<=inp[434];
out[463]<=inp[978];
out[464]<=inp[498];
out[465]<=inp[18];
out[466]<=inp[562];
out[467]<=inp[82];
out[468]<=inp[626];
out[469]<=inp[146];
out[470]<=inp[690];
out[471]<=inp[210];
out[472]<=inp[754];
out[473]<=inp[274];
out[474]<=inp[818];
out[475]<=inp[338];
out[476]<=inp[882];
out[477]<=inp[402];
out[478]<=inp[946];
out[479]<=inp[466];
out[480]<=inp[48];
out[481]<=inp[592];
out[482]<=inp[112];
out[483]<=inp[656];
out[484]<=inp[176];
out[485]<=inp[720];
out[486]<=inp[240];
out[487]<=inp[784];
out[488]<=inp[304];
out[489]<=inp[848];
out[490]<=inp[368];
out[491]<=inp[912];
out[492]<=inp[432];
out[493]<=inp[976];
out[494]<=inp[496];
out[495]<=inp[16];
out[496]<=inp[560];
out[497]<=inp[80];
out[498]<=inp[624];
out[499]<=inp[144];
out[500]<=inp[688];
out[501]<=inp[208];
out[502]<=inp[752];
out[503]<=inp[272];
out[504]<=inp[816];
out[505]<=inp[336];
out[506]<=inp[880];
out[507]<=inp[400];
out[508]<=inp[944];
out[509]<=inp[464];
out[510]<=inp[1008];
out[511]<=inp[528];
out[512]<=inp[17];
out[513]<=inp[561];
out[514]<=inp[81];
out[515]<=inp[625];
out[516]<=inp[145];
out[517]<=inp[689];
out[518]<=inp[209];
out[519]<=inp[753];
out[520]<=inp[273];
out[521]<=inp[817];
out[522]<=inp[337];
out[523]<=inp[881];
out[524]<=inp[401];
out[525]<=inp[945];
out[526]<=inp[465];
out[527]<=inp[1009];
out[528]<=inp[529];
out[529]<=inp[49];
out[530]<=inp[593];
out[531]<=inp[113];
out[532]<=inp[657];
out[533]<=inp[177];
out[534]<=inp[721];
out[535]<=inp[241];
out[536]<=inp[785];
out[537]<=inp[305];
out[538]<=inp[849];
out[539]<=inp[369];
out[540]<=inp[913];
out[541]<=inp[433];
out[542]<=inp[977];
out[543]<=inp[497];
out[544]<=inp[79];
out[545]<=inp[623];
out[546]<=inp[143];
out[547]<=inp[687];
out[548]<=inp[207];
out[549]<=inp[751];
out[550]<=inp[271];
out[551]<=inp[815];
out[552]<=inp[335];
out[553]<=inp[879];
out[554]<=inp[399];
out[555]<=inp[843];
out[556]<=inp[463];
out[557]<=inp[1007];
out[558]<=inp[527];
out[559]<=inp[47];
out[560]<=inp[591];
out[561]<=inp[111];
out[562]<=inp[655];
out[563]<=inp[175];
out[564]<=inp[719];
out[565]<=inp[239];
out[566]<=inp[783];
out[567]<=inp[303];
out[568]<=inp[847];
out[569]<=inp[367];
out[570]<=inp[911];
out[571]<=inp[431];
out[572]<=inp[975];
out[573]<=inp[495];
out[574]<=inp[15];
out[575]<=inp[559];
out[576]<=inp[979];
out[577]<=inp[499];
out[578]<=inp[119];
out[579]<=inp[563];
out[580]<=inp[83];
out[581]<=inp[627];
out[582]<=inp[147];
out[583]<=inp[691];
out[584]<=inp[211];
out[585]<=inp[755];
out[586]<=inp[275];
out[587]<=inp[275];
out[588]<=inp[817];
out[589]<=inp[339];
out[590]<=inp[833];
out[591]<=inp[403];
out[592]<=inp[947];
out[593]<=inp[467];
out[594]<=inp[1011];
out[595]<=inp[531];
out[596]<=inp[51];
out[597]<=inp[595];
out[598]<=inp[115];
out[599]<=inp[659];
out[600]<=inp[179];
out[601]<=inp[723];
out[602]<=inp[243];
out[603]<=inp[787];
out[604]<=inp[307];
out[605]<=inp[851];
out[606]<=inp[371];
out[607]<=inp[915];
out[608]<=inp[435];
out[609]<=inp[141];
out[610]<=inp[685];
out[611]<=inp[205];
out[612]<=inp[749];
out[613]<=inp[269];
out[614]<=inp[813];
out[615]<=inp[333];
out[616]<=inp[877];
out[617]<=inp[397];
out[618]<=inp[941];
out[619]<=inp[461];
out[620]<=inp[1005];
out[621]<=inp[525];
out[622]<=inp[45];
out[623]<=inp[589];
out[624]<=inp[109];
out[625]<=inp[653];
out[626]<=inp[173];
out[627]<=inp[717];
out[628]<=inp[237];
out[629]<=inp[781];
out[630]<=inp[301];
out[631]<=inp[845];
out[632]<=inp[909];
out[633]<=inp[429];
out[634]<=inp[493];
out[635]<=inp[13];
out[636]<=inp[557];
out[637]<=inp[77];
out[638]<=inp[621];
out[639]<=inp[917];
out[640]<=inp[437];
out[641]<=inp[981];
out[642]<=inp[501];
out[643]<=inp[21];
out[644]<=inp[565];
out[645]<=inp[85];
out[646]<=inp[629];
out[647]<=inp[149];
out[648]<=inp[693];
out[649]<=inp[213];
out[650]<=inp[757];
out[651]<=inp[277];
out[652]<=inp[821];
out[653]<=inp[341];
out[654]<=inp[885];
out[655]<=inp[405];
out[656]<=inp[949];
out[657]<=inp[469];
out[658]<=inp[1013];
out[659]<=inp[533];
out[660]<=inp[53];
out[661]<=inp[597];
out[662]<=inp[117];
out[663]<=inp[661];
out[664]<=inp[181];
out[665]<=inp[725];
out[666]<=inp[245];
out[667]<=inp[789];
out[668]<=inp[309];
out[669]<=inp[853];
out[670]<=inp[373];
out[671]<=inp[203];
out[672]<=inp[747];
out[673]<=inp[267];
out[674]<=inp[811];
out[675]<=inp[331];
out[676]<=inp[875];
out[677]<=inp[395];
out[678]<=inp[939];
out[679]<=inp[459];
out[680]<=inp[1003];
out[681]<=inp[523];
out[682]<=inp[43];
out[683]<=inp[587];
out[684]<=inp[107];
out[685]<=inp[65];
out[686]<=inp[171];
out[687]<=inp[715];
out[688]<=inp[235];
out[689]<=inp[779];
out[690]<=inp[299];
out[691]<=inp[843];
out[692]<=inp[363];
out[693]<=inp[907];
out[694]<=inp[427];
out[695]<=inp[971];
out[696]<=inp[491];
out[697]<=inp[11];
out[698]<=inp[555];
out[699]<=inp[75];
out[700]<=inp[619];
out[701]<=inp[139];
out[702]<=inp[683];
out[703]<=inp[855];
out[704]<=inp[375];
out[705]<=inp[919];
out[706]<=inp[439];
out[707]<=inp[483];
out[708]<=inp[503];
out[709]<=inp[23];
out[710]<=inp[567];
out[711]<=inp[87];
out[712]<=inp[631];
out[713]<=inp[151];
out[714]<=inp[695];
out[715]<=inp[215];
out[716]<=inp[759];
out[717]<=inp[279];
out[718]<=inp[823];
out[719]<=inp[343];
out[720]<=inp[887];
out[721]<=inp[407];
out[722]<=inp[915];
out[723]<=inp[471];
out[724]<=inp[1015];
out[725]<=inp[535];
out[726]<=inp[55];
out[727]<=inp[599];
out[728]<=inp[199];
out[729]<=inp[663];
out[730]<=inp[183];
out[731]<=inp[727];
out[732]<=inp[247];
out[733]<=inp[791];
out[734]<=inp[311];
out[735]<=inp[265];
out[736]<=inp[809];
out[737]<=inp[329];
out[738]<=inp[873];
out[739]<=inp[393];
out[740]<=inp[937];
out[741]<=inp[475];
out[742]<=inp[1001];
out[743]<=inp[521];
out[744]<=inp[41];
out[745]<=inp[585];
out[746]<=inp[105];
out[747]<=inp[644];
out[748]<=inp[169];
out[749]<=inp[713];
out[750]<=inp[233];
out[751]<=inp[777];
out[752]<=inp[297];
out[753]<=inp[841];
out[754]<=inp[361];
out[755]<=inp[905];
out[756]<=inp[425];
out[757]<=inp[969];
out[758]<=inp[489];
out[759]<=inp[9];
out[760]<=inp[553];
out[761]<=inp[73];
out[762]<=inp[617];
out[763]<=inp[137];
out[764]<=inp[681];
out[765]<=inp[201];
out[766]<=inp[745];
out[767]<=inp[793];
out[768]<=inp[313];
out[769]<=inp[857];
out[770]<=inp[377];
out[771]<=inp[921];
out[772]<=inp[441];
out[773]<=inp[985];
out[774]<=inp[505];
out[775]<=inp[25];
out[776]<=inp[569];
out[777]<=inp[89];
out[778]<=inp[633];
out[779]<=inp[153];
out[780]<=inp[697];
out[781]<=inp[217];
out[782]<=inp[761];
out[783]<=inp[281];
out[784]<=inp[825];
out[785]<=inp[345];
out[786]<=inp[889];
out[787]<=inp[409];
out[788]<=inp[953];
out[789]<=inp[473];
out[790]<=inp[1017];
out[791]<=inp[537];
out[792]<=inp[57];
out[793]<=inp[601];
out[794]<=inp[121];
out[795]<=inp[665];
out[796]<=inp[185];
out[797]<=inp[729];
out[798]<=inp[249];
out[799]<=inp[327];
out[800]<=inp[871];
out[801]<=inp[391];
out[802]<=inp[935];
out[803]<=inp[455];
out[804]<=inp[999];
out[805]<=inp[519];
out[806]<=inp[39];
out[807]<=inp[583];
out[808]<=inp[103];
out[809]<=inp[647];
out[810]<=inp[167];
out[811]<=inp[711];
out[812]<=inp[231];
out[813]<=inp[775];
out[814]<=inp[295];
out[815]<=inp[839];
out[816]<=inp[359];
out[817]<=inp[903];
out[818]<=inp[423];
out[819]<=inp[967];
out[820]<=inp[487];
out[821]<=inp[7];
out[822]<=inp[551];
out[823]<=inp[71];
out[824]<=inp[615];
out[825]<=inp[135];
out[826]<=inp[679];
out[827]<=inp[199];
out[828]<=inp[743];
out[829]<=inp[263];
out[830]<=inp[807];
out[831]<=inp[731];
out[832]<=inp[251];
out[833]<=inp[796];
out[834]<=inp[5];
out[835]<=inp[315];
out[836]<=inp[859];
out[837]<=inp[379];
out[838]<=inp[923];
out[839]<=inp[443];
out[840]<=inp[987];
out[841]<=inp[507];
out[842]<=inp[27];
out[843]<=inp[571];
out[844]<=inp[91];
out[845]<=inp[635];
out[846]<=inp[165];
out[847]<=inp[699];
out[848]<=inp[219];
out[849]<=inp[763];
out[850]<=inp[283];
out[851]<=inp[827];
out[852]<=inp[347];
out[853]<=inp[891];
out[854]<=inp[411];
out[855]<=inp[955];
out[856]<=inp[475];
out[857]<=inp[1019];
out[858]<=inp[539];
out[859]<=inp[59];
out[860]<=inp[603];
out[861]<=inp[123];
out[862]<=inp[667];
out[863]<=inp[187];
out[864]<=inp[389];
out[865]<=inp[933];
out[866]<=inp[453];
out[867]<=inp[997];
out[868]<=inp[517];
out[869]<=inp[37];
out[870]<=inp[581];
out[871]<=inp[101];
out[872]<=inp[645];
out[873]<=inp[165];
out[874]<=inp[709];
out[875]<=inp[229];
out[876]<=inp[773];
out[877]<=inp[293];
out[878]<=inp[837];
out[879]<=inp[357];
out[880]<=inp[901];
out[881]<=inp[421];
out[882]<=inp[965];
out[883]<=inp[485];
out[884]<=inp[5];
out[885]<=inp[549];
out[886]<=inp[69];
out[887]<=inp[613];
out[888]<=inp[133];
out[889]<=inp[677];
out[890]<=inp[197];
out[891]<=inp[741];
out[892]<=inp[261];
out[893]<=inp[805];
out[894]<=inp[325];
out[895]<=inp[869];
out[896]<=inp[669];
out[897]<=inp[189];
out[898]<=inp[733];
out[899]<=inp[253];
out[900]<=inp[797];
out[901]<=inp[317];
out[902]<=inp[861];
out[903]<=inp[381];
out[904]<=inp[925];
out[905]<=inp[445];
out[906]<=inp[989];
out[907]<=inp[509];
out[908]<=inp[29];
out[909]<=inp[573];
out[910]<=inp[93];
out[911]<=inp[637];
out[912]<=inp[157];
out[913]<=inp[701];
out[914]<=inp[221];
out[915]<=inp[765];
out[916]<=inp[285];
out[917]<=inp[829];
out[918]<=inp[349];
out[919]<=inp[893];
out[920]<=inp[413];
out[921]<=inp[957];
out[922]<=inp[477];
out[923]<=inp[1021];
out[924]<=inp[541];
out[925]<=inp[61];
out[926]<=inp[605];
out[927]<=inp[125];
out[928]<=inp[451];
out[929]<=inp[995];
out[930]<=inp[515];
out[931]<=inp[35];
out[932]<=inp[579];
out[933]<=inp[99];
out[934]<=inp[643];
out[935]<=inp[163];
out[936]<=inp[707];
out[937]<=inp[227];
out[938]<=inp[771];
out[939]<=inp[191];
out[940]<=inp[835];
out[941]<=inp[355];
out[942]<=inp[899];
out[943]<=inp[419];
out[944]<=inp[963];
out[945]<=inp[483];
out[946]<=inp[3];
out[947]<=inp[547];
out[948]<=inp[67];
out[949]<=inp[611];
out[950]<=inp[131];
out[951]<=inp[675];
out[952]<=inp[195];
out[953]<=inp[739];
out[954]<=inp[259];
out[955]<=inp[803];
out[956]<=inp[323];
out[957]<=inp[867];
out[958]<=inp[387];
out[959]<=inp[931];
out[960]<=inp[607];
out[961]<=inp[127];
out[962]<=inp[671];
out[963]<=inp[191];
out[964]<=inp[735];
out[965]<=inp[255];
out[966]<=inp[799];
out[967]<=inp[319];
out[968]<=inp[863];
out[969]<=inp[383];
out[970]<=inp[927];
out[971]<=inp[447];
out[972]<=inp[991];
out[973]<=inp[511];
out[974]<=inp[31];
out[975]<=inp[575];
out[976]<=inp[95];
out[977]<=inp[639];
out[978]<=inp[159];
out[979]<=inp[703];
out[980]<=inp[223];
out[981]<=inp[767];
out[982]<=inp[287];
out[983]<=inp[831];
out[984]<=inp[351];
out[985]<=inp[895];
out[986]<=inp[415];
out[987]<=inp[959];
out[988]<=inp[479];
out[989]<=inp[1023];
out[990]<=inp[543];
out[991]<=inp[63];
out[992]<=inp[513];
out[993]<=inp[33];
out[994]<=inp[577];
out[995]<=inp[97];
out[996]<=inp[641];
out[997]<=inp[161];
out[998]<=inp[705];
out[999]<=inp[225];
out[1000]<=inp[769];
out[1001]<=inp[289];
out[1002]<=inp[833];
out[1003]<=inp[353];
out[1004]<=inp[397];
out[1005]<=inp[417];
out[1006]<=inp[961];
out[1007]<=inp[481];
out[1008]<=inp[1];
out[1009]<=inp[545];
out[1010]<=inp[65];
out[1011]<=inp[609];
out[1012]<=inp[129];
out[1013]<=inp[673];
out[1014]<=inp[193];
out[1015]<=inp[737];
out[1016]<=inp[257];
out[1017]<=inp[801];
out[1018]<=inp[321];
out[1019]<=inp[865];
out[1020]<=inp[385];
out[1021]<=inp[929];
out[1022]<=inp[449];
out[1023]<=inp[90];
end
end
always@ ( posedge outclk or posedge clr)
begin
#0.1;
if (clr)
out1<=0;
else
begin
{out1[1023:b]}<={out[1023-b:0]};
{out1[c:0]}<={out[1023:1023-c]};
end
end
endmodule
For this i could not go thru all your code, as am out of station, once i get back i ll try to help u
Here u trying to use 2048 input and output lines for tht FPGA, whre as the FPGA is having only 232 only... one main constraint in FPGA is u cannot have this big input or output ports for this u need to take the input in time multiplexing mode andsame with the output
    jameela
ok...waiting.............................................................
Here the size delaration on s21 is contradacting.., as below
please make this change..
when ins==1, wait for 2 clock cycles on out_clk for seeing the getting
32'b 10101010101010101010101010101010 and when ins == 0, also u need to wait for 2 clock cycles to get s21= 32'b 01010101010101010101010101010101
Ur q is not clear
    jameela
1) delays are not synthesizable...then how to wait for 2 clock cycles in each case?
2) inp is actually a buffer having a size of [1023:0]
inp is to be filled by whatever bits come on s21 ,one by one on every clock edge
meaning thereby that 1 bit comes from s21 and fills inp[0] on 1st posedge of clock then 2nd bit appears on s21 which fills inp[0] and the previous bit which was on inp[0] now goes to inp[1] on 2nd posedge of clock and hence so on....
now when i simulate this code it shows proper shifting in the way described but only upto 1600ns after 1600ns there is no shifting shown and all inp[0].......inp[1023] lines in the waveform show 1....how to correct it?
i hope i have clarified myself...
i am not asking to insert delays in the RTL, you need to wait for 2 clock edges to get correct data..
coz
s2<=s1; will take 1 clk pulse
and
s21<=s2; will take 1 clock pulse..
so u can see correct data on s21 after 2 clock pulses of s1.,
2 inp is actually a buffer having a size of [1023:0]
you are always assigning LSB bit of s21 to inp, if you can assign LSB 1 st bit in 1 clock edge and 2nd bit in 2nd clock edge then u logic will work according to u
