error for 64 bit ripple carry adder
Mahammad
Member level 3
Member level 3
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
module rippl(
    input [63:0] a,
    input [63:0] b,
    input cin,
    output [63:0] s,
    output cout
wire temp[63:0];
assign temp[0]=cin;
genvar i;
always @(*)
for(i=0;i<64;i=i+1)
begin
s[i]<=(a[i]^(b[i]^temp[i]));
temp[i+1]<=(((a[i]&b[i])|(b[i]&temp[i]))|(temp[i]&a[i]));
end
assign cout=temp[63];
end
endmodule
You will avoid a lot of problems if you use blocking assignments "=" in combinatorial always blocks and non-blocking assignments "<=" in clocked always blocks until you understand when to break this rule.
what exactly is the error, need some explanation
temp is too small. The generate will assign to temp[63+1].
besides that, it should be doing the following assign for cout to get the carry output of the add.
assign cout = temp[64];
